rbkla
Plant tag shows zeros after decimal
I am using Vectorworks 2019 and I have the problem of decimals after the plant numbers on a planting plan.  I have never had this before.  Please can someone confirm how I fix this??
Thanks
Go to the Tools menu > Database > Record Format Connection.
Locate the Plant Record in the list, select it then click Edit.
Select the Quantity field then click Edit.
Change the Type to Integer and set the default value to zero.
Click OK 3 times.
If everything does not update correctly, then choose Reset All Plug-ins from the Tools > Utilities menu.
  • Like 3
On 8/6/2020 at 4:38 PM, Tamsin Slatter said:
I am not experiencing this at all anymore. I think it might be an old template issue. If you use the Garden Design template that's provided with 2020, do you still see the problem?
I used the Garden Design template to create a new template and it still happens.
Yes, the problem is still happening.
On 10/8/2020 at 11:24 AM, Starbug said:
Below is how to fix the plant quantities displaying to 2 decimal places:
1. Go to the Tools menu > Database > Record Format Connection.
2. Locate the Plant Record in the list, select it then click Edit.
3. Select the Quantity field then click Edit.
4. Change the Type to Integer and set the default value to zero.
5. Click OK 3 times.
6. Set opacity to 100% (I know, madness but this refreshes the display).
This is the temporary fix I use. The next time I open the file and add a plant, the decimal places issue returns, and I have to go through all of this again. Every day on every file.
