Vectorworks, Inc Employee TomWhiteLight Posted November 23, 2018 Vectorworks, Inc Employee Share Posted November 23, 2018 Hello, New to Braceworks, My Suspended hanging positions are behaving nicely but the truss they are suspended from is giving me an error message saying the static system is not supported. I am not sure how to hang this position as insert drop doesn't want to connect to an inserted house position? Any thoughts? Thanks! Quote Link to comment
Vectorworks, Inc Employee jcogdell Posted December 5, 2018 Vectorworks, Inc Employee Share Posted December 5, 2018 Hi Tom From your description you are trying to hang the upper (or pre-rig) truss using the 'insert connection' tool, this will not work as it is designed only to connect between trusses and/or pipes. To hang your pre-rig truss correctly (for braceworks calculations) there are a number of possible methods, The quickest is to use the 'insert hoist tool', attach the motors to the truss and then adjust the high hook field in the OIP to match the height of your house rigging point The next is to right click on the 'insert hoist tool' and select 'insert deadhang' option, attach the deadhangs to your truss and adjust the chain length and shorten field in the OIP to the desired heights. In both the above methods it is not necessary to attach the hoist or deadhang to a house rigging point and the newton loads will be displayed both in the OIP and on the hoist or deadhang label A third way is to use the 'insert bridle tool', for this you have to first either insert house rigging points or structural members using the appropriate tool and then go into the bridle preferences in the spotlight rigging menu to tell the tool which it should attach to. Next select the 'insert bridle tool' and select the type of bridle you want to insert (single/ deadhang, 2 leg, 3leg, etc) then insert your bridles. The advantage of this last method is that the bridle tool will generate diagrams of the bridles and associated material lists for your rigging team, both saving time on the get in day and helping with the pack list planning. If you need any further help give me a shout using Slack or by email and we can share a screen, I am based in Berlin so the time difference is not a big problem. gruße Jesse 2 Quote Link to comment
Vectorworks, Inc Employee TomWhiteLight Posted December 6, 2018 Author Vectorworks, Inc Employee Share Posted December 6, 2018 Thanks for clearing this up Jesse! Most helpful! 1 Quote Link to comment
andref Posted March 19, 2024 Share Posted March 19, 2024 Hi, All just reading the post above.. and i have a question. I use vectorworks for touring and temporary instalation drawings... in most of the cases i don´t really have a clear info for the stages and 3D structural draws.... but we do get riggings points and loads. in cases like this we normally use a pre Rig attach to the stage structure... in order to have this connect to a hanging point and avoid the message "the static system is not supported" whats the best tool to use? thanks in advance! Quote Link to comment
Vectorworks, Inc Employee Scott C. Parker Posted March 21, 2024 Vectorworks, Inc Employee Share Posted March 21, 2024 Have you tried the House Rigging Point tool? 1 Quote Link to comment
