avictorgm
How to read the value of a field (linked to databank) of a symbol
Hello,
I am kind of new on Python but not on Vectorworks.
I have a custom symbol that contains 2 text labels: one contains a number like "2,43", the other is always the same text not attached to the database.
I need to get read that "2,43"
and later do the contrary: be able to write into the field in the symbol another number.
some ideas?
Edited by avictorgm
Your easiest approach is to link the text to a record field (see the help guide for Link Text to Record).  Then, you can write a simple script using vs.SetRField and vs.GetRField to write and read the data.
Thanks for the answer,
Yes, it´s already done:
I have a group of symbols already linked between the database and the field Deckenlast.
I have found this on the web from Makro, but gave me back "0", "0" and   " ", " "
Some help?
import vs
hpio = vs.FSActLayer().                                                # this MUST give back the first element of the active layer, BUT I think is NOT.
hrecdef = vs.GetParametricRecord(hpio).
recname = vs.GetName(hrecdef)  # Name of PIO in InfoPalette
hrec = vs.GetObject(recname)
fld = vs.GetFldName(hrec, 10).         #. I AM NOT SURE ABOUT THIS 10
vs.AlrtDialog(vs.GetTypeN(hrecdef))  # 48. answer "0"
vs.AlrtDialog(vs.GetTypeN(hrec))  # 47. answer "0"
vs.AlrtDialog('Recordname:' + recname).   #. answer " "
vs.AlrtDialog('Default:' + vs.GetRField(hrec, recname, fld)).  #. answer " "
# ©MaKro - June 2018 😉
Vectorscript Symbol read.vwx
The example you have is for a plug-in object.  If you're just dealing with linked-record symbols, the script can be a little simpler.
# This gets a "handle" — a runtime object ID — to the first selected object on the active layer.
hObject = vs.FSActLayer
You mentioned a group of symbols — that makes this a little more difficult, as you need to get a handle to the symbols in your first selected object.  You can either get the first object in the group with vs.FInGroup(hObject) and then iterate through the group, use one of the ForEachObject routines to iterate through every object meeting your specifications, or use the "waldo" technique (there should be some posts in the archive on this) to find your place in the document.  If you don't mean a literal group of symbols, then cary on.
# Get the value of the field.  You didn't mention the name of the record, so there is a placeholder
fieldDataS =  vs.GetRField( hObject, YOUR_RECORD_NAME, 'Deckenlast' )
# This always returns a string, so you need to convert it to a number
ok, fieldData = vs.ValidNumStr( fieldDataS )
if not ok
     fieldData = 0
ValidNumStr deals well with units and separator preferences, so is going to be the most robust option versus vs.Str2Num or eval().  You may want to write your own function .
def Num2Str( x )
    ok, n = vs.ValisNumStr( x )
    if not ok:
        n = 0
    return n
vs.SetRfield also requires a formatted string argument — use vs.Str2NumF for this
@JBenghiat Joshua,  Can you please also comments on the idea of not using the actual parameter records in the dialog box and rather copying the original value into a variable to use in the dialog box and then writing the value back to the parameter record after the OK button is clicked.
I seem to remember that this was considered best practice, but don't have time to find the appropriate threads right now.
Do you mean for AlrtDialog?  You should be fine entering any data here, and in fact the arguments don't need to be strings, like Message() in VS.
Or are you thinking of the fact that PParamName doesn't update after SetRField( ParamName )?  As we're dealing with symbols and records, that doesn't even apply here.
At the end
I GOT IT!!!!
Took me a little, but after this a whole world of possibilities has opened to me!
import vs
#Vistor Garzon 2020 based on the work of
# ©MaKro - June 2018 ;-)
H1 = vs.FSActLayer()
H2 = vs.ActSymDef(H1)
recname = vs.GetName(H2)  # Name of PIO in InfoPalette
Rec_Name = vs.GetObject(recname)
fld = vs.GetRField(H1,'loads-roof','Deckenlast')
##### vs.GetRField(h,'DatabankName','FieldName')
vs.AlrtDialog(fld)
