I was curious if anyones else has seen this issue. I have a model that has several curved walls that I created using the "Round wall" tool. I was setting up a Plan view viewport and a RCP viewport on a a sheet layer. The viewports were created using the clip cube. The Plan view viewport looks fine other than the curve in Hidden Line render looks more like lots of small straight line segments compared to how it looks in the design layer. So I then created the RCP viewport, everything looked similar to the Plan view but to place in on the sheet with the same positioning as the Plan view I of course needed to rotate 180 degrees and then rotate horizontal. After I completed the rotations any round wall that has a window or door inserted now have two complete circles in the viewport showing the extends ( inside & outside of the wall ). If I remove the doors and windows the circles disappear, and as soon as I place them back in the wall the circles reappear. In the attached file you will noticed the the door swings on several of the doors show up 270 degrees not the normal 90 degrees.
Hello,
