Content Count
204 -
Community Reputation
29 GreatAbout Haydenovative
Rank
Journeyman
Personal Information
Occupation
Operations/CAD Manager
Homepage
www.innovative.net.au
Location
New South Wales, Australia
Contact Info
Skype
hayden@innovative.net.au
Recent Profile Visitors
1,095 profile views
Good Afternoon Team, I have created a very complex 3D venue that we are in-house in. Occasionally we need to do accurate 3D renders and so every little nook and cranny have been accurately modelled. We also sometimes just need to spit out simple 2D plans and so, I'd like to create a simplified, flat version where most 3D geometry is removed and the file size can be greatly reduced (Drawing is currently more than 1.2 Gigabytes). I have tried grabbing the whole venue and converting to lines, but that absolutely annihilates my computers performance. I also lose the 2D geometry of windows and doors in the conversion. I need the venue to still function, as I have marionettes to open and close doors and change bollard placements, so those elements will need to remain 3D. But I'm hoping someone has a suggestion for how to convert the drawing to a more 2D plan for ease of use and file size. Thank you so much!
Thank you @Pat Stanford, that makes a lot of sense. it is indeed a Title Block Border object. Thanks again!
- 4 replies
- 1
- titleblock
- 2021
(and 2 more)
Tagged with:
Thank you for getting back to me @Nikolay Zhelyazkov, I have attached a screen grab of the create symbol dialogue. As you can see, I don't have the "Convert to Group" tick box. It seems to be something specific to the Title Block Border symbol, any other group of objects I attempt to create a symbol from gives me the option to convert to group.
- 4 replies
- titleblock
- 2021
(and 2 more)
Tagged with:
Heya Team, I am in the process of building our new titleblock in 2021, and I've hit a bit of an issue that I'm sure has an easy fix. In previous versions I have completed the titleblock and sheet border and saved it as a group symbol (with the red text) then I could save that to our symbol library which let me drag it in to a new drawing easily. I have noticed when creating symbols now, there is no group option. This means if I save my completed titleblock and sheet border as a regular symbol it doesn't work correctly when I bring it in. I would also now like to have multiple titleblocks available depending on the project. How would you suggest I save them for easy access by all of the VW users in our company? Thanks a million!
- 4 replies
- titleblock
- 2021
(and 2 more)
Tagged with:
Howdy Gang, We've noticed an interesting issue and perhaps its a misunderstanding, or something we should pop on the wish list. With the newish Video camera tool, and linking it to a viewport. The tool currently works similarly to the renderworks camera tool in that you can choose to link it to a viewport and it disappears from the design layer, or you leave it in place and create the viewport separately. We are working in a TV studio and we would like the camera to remain in the design layer, as well as creating a viewport. Once the copy has been made, they are no longer linked, this means if you tilt the viewport camera slightly, it is now inside of the geometry of the camera and the viewport turns out blue. What we would like is that every time we move the physical camera in the design layer, it is updated in the viewport, leaving them linked, rather than it being a copy. Perhaps something for the wish list.
- 5 replies
- 4
- video camera
- video
(and 2 more)
Tagged with:
Extending handrail to stair landing
Haydenovative replied to Matt Hagen's topic in General Discussion
Following. I have had this issue. -
I can confirm that 2020 SP4 Windows does not take the texture applied through OIP. However, colour by class does allow me to add the texture. Not ideal for our workflow, but it will do for now. Thanks @Andy Broomell and @JustinVH.
- 5 replies
- straight truss
- texture
(and 1 more)
Tagged with:
Heya Team, I'm feeling like a real noob. Id like to know how to colour the 3D component of truss made with the straight truss tool without changing the 2D fill colour. I also cant add a texture to the 3D model, like chrome. Can anyone point me in the right direction? Thanks in advance.
- 5 replies
- straight truss
- texture
(and 1 more)
Tagged with:
Heya Team, I am trying to create a layer filled with symbol insert wrappers. I have got it working but it always inserts the symbol on the same layer the wrapper is on, where do I place the command to tell the wrapper which layer to send that symbol to? Thanks in Advance!
- 1 reply
- marionette
- insert
(and 1 more)
Tagged with:
Generic Solid or Solid Addition?
Haydenovative replied to Haydenovative's topic in General Discussion
@EAlexander, do you find that there is an increase in the performance of the drawing once you've converted it? Is that the reason you choose to convert? -
Heya Gang, I work in event design and i have a question for the think tank. If i have created a rather complex object with fillets, solid additions and subtractions, maybe some sweeps etc. and I then convert that into a symbol. Am I better off leaving it as a solid addition, or once I'm happy with it should I convert that to a generic solid? I'm thinking about the drag it has on working with the drawing, is there a simple better option her for performance?
Twinmotion Plugin + Sync
Haydenovative replied to Tom Klaber's question in Wishlist - Feature and Content Requests
Hi @JRA-Vectorworks-CAD, I agree completely. The SketchUP direct link looks to be very useful and would help the two work together without clunky workarounds. Eagerly awaiting news of this links progress. -
Awesome, found it. What a life saver. Thanks so much @Hans-Olav -
@Hans-Olav How are you toggling between changing a single item or everything of a texture at once? -
@JRA-Vectorworks-CAD Thank you very much for sharing that link, a wonderful explanation of your process.
