Raymond 4 Posted June 11, 2018 Hey guys, I'm just trying to change the line weight of a hand rail object in the elevation/section viewport. I'm sure this is possible, however I haven't been able to find the solution. My desired lineweight is 0.13mm, however it displays thicker in elevation/section view. I've included images of the OIP and attributes. The layer that the object is placed on is set to 0.13mm, but as you can see this is not the case. Thanks, Raymond Quote Share this post Link to post
0 Btreen 4 Posted June 11, 2018 I believe the line weights are being controlled by the class Annotations-Rail Set the class line weight to 0.13 and your handrail line weights should follow. Quote Share this post Link to post
0 Raymond 4 Posted June 11, 2018 @Btreen The line weight for this class is already set to 0.13mm. I have tried changing it to 1.0mm from the class organization window. This has no effect on the handrail object when updating the section viewport. Quote Share this post Link to post
0 AlanW 521 Posted June 12, 2018 (edited) @Raymondhi, try setting the attributes to all by Class then change the Class line weight. I will always use everything by Class unless I specifically need one item different. Edited June 12, 2018 by Alan Woodwell Quote Share this post Link to post
0 Raymond 4 Posted June 12, 2018 @Alan Woodwell Hey Alan, this worked. Thanks! 1 Quote Share this post Link to post
Thanks,
Raymond
