Stephanie Desmeules Posted May 3, 2018 Share Posted May 3, 2018 Is it possible to organize a plant record so that plants are organized under a trees, shrubs and perennials subtitles (ex) and in an alphabetical order? Thank you! Quote Link to comment
J. Wallace Posted May 4, 2018 Share Posted May 4, 2018 (edited) Yes, that is easy to do @Stephanie Desmeules I suggest you take a look at the help section of VW and search under worksheets. You have to open up a worksheet and view database headers to modify the sheet. It takes a bit of getting used to but once you have understood how to modify the sheet it's very easy. You end up editing the criteria for rows and add functions to the columns such as this ='Plant Record'.'ID' Edited May 4, 2018 by J. Wallace 1 Quote Link to comment
bob cleaver Posted May 4, 2018 Share Posted May 4, 2018 We use the category fill in on the plant definition to label, tree, shrub, etc and then sort the database for separation of plant types We use plant definition Comment 1, 2, 3 for CA Native, Evergreen, WELO rating and add them to the plant list columns We would love to read other workflows Quote Link to comment
Stephanie Desmeules Posted May 9, 2018 Author Share Posted May 9, 2018 Thank you J. Wallace, I got up to editing the criteria for rows but I don't have the option "='Plant Record'.'ID' "... So i'm not sure what to di next...! If you don't mind I would really appreciate a little more details as to how to proceed! (if you have time of course!) The help section in VW did not bring any informations, other than pointing to my plant record... Thank you so much Stephanie Quote Link to comment
Stephanie Desmeules Posted May 9, 2018 Author Share Posted May 9, 2018 Thank you so much Bob Cleaver, Could you be more specific as to how you sort the database for separation of plant types...? Thank you for your time! Stephanie Quote Link to comment
Pat Stanford Posted May 10, 2018 Share Posted May 10, 2018 I have posted a couple of long posts about worksheets in the last month. Take a look and see if they help you. While not specifically about Plants, the ideas are the same. If they are not enough help, ask again. Quote Link to comment
