zeno Posted March 28, 2018 Share Posted March 28, 2018 Specifically in Italy and in rest of Europe is a very import issue to have thickness wall control. Every architect that comes from 2D draw and need to improvement the workflow switching to BIM ask us: "how can I create a variable thickness wall?". How about add this improvement to next vectorworks versions? Thanks 2 Quote Link to comment
0 markdd Posted March 28, 2018 Share Posted March 28, 2018 Is this what you are trying to do? Quote Link to comment
0 zeno Posted March 28, 2018 Author Share Posted March 28, 2018 Not precisely. What we need is to manage the entire wall in creation phase. F.e creating a 3D model, free 3D model, convert it in a Wall, and add windows door etcetera. Or to set a different thickness from start to end. I know the projection command but you can't add a window and have a hole automatically Quote Link to comment
0 zoomer Posted March 28, 2018 Share Posted March 28, 2018 (edited) As far as I know the Window should go through. The only problem I have with these Wall adaption options is at the ends of Walls and Joining. Edited March 28, 2018 by zoomer Quote Link to comment
0 zeno Posted March 28, 2018 Author Share Posted March 28, 2018 6 minutes ago, zoomer said: As far as I know the Window should go through. The only problem I have with these Wall adaption options is at the ends of Walls and Joining. Please zoomer show me the light beacause I'll be happy if I'm wrong :-D Quote Link to comment
0 zoomer Posted March 28, 2018 Share Posted March 28, 2018 (edited) I just tried. It seems to fail if you insert the Window from the wrong side (the feature side) as it selects the feature and hides the Wall from Window insertion. I rotated the View and could pick the Wall in the feature area, Window inserted into Wall and goes through as it should. But man works insertion slow .... Edited March 28, 2018 by zoomer Quote Link to comment
zeno
Thanks
5 answers to this question
