Clip Surface command gone crazy
MikeN
Are either of your objects set to a class other than the active class? If so, is your class setting Show/Snap/Modify Others? I recently ran into a similar problem because I had inadvertantly reset my class visibility - maybe your new file in 10.5.1 isn't set the way you think.
[ 02-16-2004, 12:54 AM: Message edited by: P Retondo ]
VW 10 changed many of the default keyboard-command equivalents. Are you by chance trying to initiate Clip Surface from the keyboard using an "old" (but familiar) key combination? If so, you need to modify the workspace. . .with which I assume you're familiar.
[ 02-16-2004, 05:02 PM: Message edited by: Travis Tolman ]
