Hi everyone. this is just a quick workflow query really, rather than an issue or a bug.
When you work in 3d, adding subtrating and so on, it's really handy to have one version which is as modelled, but then I like to take a boolean shape and go back to the primitives... with most objects you can just go "ungroup" to your hearts content until you get back to source.... But with extrudes you can't. you need to go into the extrude and then copy/paste the shape out.
Main reason is, when you're viewporting the 3d extrude, the circles, curves and drills come out multi-faceted according to your 3d conversion res setting.... but I'd like to display them in drawings as true curves. (This would allow associative dimensions to be used also, expecially hole diameter and so on.... instead, I'm taking a 3d viewport and overlaying real circles onto the flattened 3d and appying centre-marks, dims etc...
Is my workflow missing a trick or two here? I suspect it is!
RussU
3 answers to this question
