pclary Posted November 16, 2016 Share Posted November 16, 2016 In making sheet views with viewports, the Drawing Labels are starting to come in misaligned. See attachment. I can 'fix' them by ungrouping (ignoring the warning: are you sure you want to ungroup high level...) and then moving the scale text but this breaks the intelligent link to the proper scale. Any help? Thanks Quote Link to comment
AlanW Posted November 16, 2016 Share Posted November 16, 2016 (edited) Hi, you probably have your setting set to negative. see attached in the OIP I set it to Negative 5 to produce the same effect. HTH Edited November 16, 2016 by Alan Woodwell Quote Link to comment
pclary Posted November 16, 2016 Author Share Posted November 16, 2016 Thanks for the reply Alan. Unfortunately, I have that setting at 0.000. If I change it it to 0.25 I get the correct position. Any ideas on why the Drawing Label is behaving this way? Quote Link to comment
Andy Broomell Posted November 16, 2016 Share Posted November 16, 2016 I see that "Text Style" is set to "Class Style". Does your class have a text style associated with it? I've encountered some similar bugginess with Drawing Labels trying to use class text styles. Quote Link to comment
pclary Posted November 16, 2016 Author Share Posted November 16, 2016 Andy, yes I do have text style associated with the class. I'll try removing that. I'm still trying to learn the best workflow and appreciate any help. Thanks Quote Link to comment
