joelhufford 1 Posted June 26, 2015 Hi, Wondering about something I'm running into in VW2015 - although I expect this happens regardless of which version you're on. I'm cleaning up a drawing and when I go to delete a class that's no longer in use, occasionally I'm shown this dialog box. [img:center]https://www.dropbox.com/s/2yns4hfspseu5dn/deleting%20classes.png?dl=0[/img] So I'm wondering if there's a quick way to have Vectorworks tell you how many objects are currently assigned to the class? Using a custom selection of this old class, as well as the visibility tool to temporarily make every class visible doesn't cause anything new to show up. Quote Share this post Link to post
AlanW 547 Posted June 26, 2015 You could use select similar tool to show all the object on that class and you can also modify the selection in the options dialogue box. HTH Quote Share this post Link to post
Pat Stanford 1,633 Posted June 26, 2015 Take a look at this thread. https://techboard.vectorworks.net/ubbthreads.php?ubb=showflat&Number=210046Post210046 I posted a couple of scripts that will create worksheets that will show you all the classes and the number of objects in each. Start at the bottom of the thread and work backwards so you get the latest versions of the scripts. Quote Share this post Link to post
joelhufford 1 Posted June 27, 2015 Pat, That is awesome. It's exactly what I needed! Thanks so much! Quote Share this post Link to post
collins 2 Posted December 1, 2020 Hi Pat, can I ask where this thread you mention above moved to in the new site? Thanks https://techboard.vectorworks.net/ubbthreads.php?ubb=showflat&Number=210046Post210046 Quote Share this post Link to post
