Danilo Posted December 26, 2014 Author Share Posted December 26, 2014 OK, so I still have not pulled the trigger and asked for a quote on a higher grade of machine. Any thoughts on this setup? Dell Precision Workstation Intel Xeon E5 1607 Processor, Windows 7 Pro 16 GB RAM 3 GB NVIDIA Quadro K400 Some questions I have: Xeon vs. i7 processor? I am seeing a lot of i7's in this forum's signatures. My research tells me that the Xeon is more common in workstations, but should I be asking for an i7? Is the 3GB Quadro K400 a better GPU than the 4GB GeForce GTX 745? Are specs above significantly better than the specs below? The specs above are coming in at $900 more than those below. ***** previous specs/older quote ***** Dell OptiPlex 9020 Desktop Windows 7 Pro, 64 Bit 32 GB RAM Intel Core i7-4790 (Quad Core, 8MB, 3.60GHz w/HD4600 Graphics) 1 TB Hard Drive, DVD +/- RW, nVIDIA GeForce GTX 745, 4GB DDR3, 1 VGA, 1 DVI, 1 HDMI Quote Link to comment
grant_PD Posted December 26, 2014 Share Posted December 26, 2014 Xeons are not worth it in my mind. You have to pay for more expensive ram and motherboard. They are made for servers that have to do high volumes of work, not for our industry. I also feel the same about the quadro, an expensive card that VW says is not preferable to the high end gaming cards. Jim probably can recommend the best card for the money. Since you are going to be working in a 64 bit environment, I would get the most ram you can, as you will be able to address more memory than you can probably fit in your machine. This means you can have piggy programs like photoshop, excel, and vw open at the same time and they will still remain more responsive. Is the hard drive solid state? Solid state drives have super fast read/write times, which can make your computer much more responsive. Don't forget as well that one of the most important upgrades you can get for a computer is your monitor. Quote Link to comment
Vectorworks, Inc Employee Vectorworks - Admin Posted December 26, 2014 Vectorworks, Inc Employee Share Posted December 26, 2014 As stated above, Xeons; while being slightly better as far as performance over say, a similar series i7 CPU, are significantly more expensive, require significantly more expensive motherboards and (sometimes) RAM as well. If you render all day every day then a 20% speed gain would be worth it, as you could save weeks out of the year in render time, but if you only do it an hour or two a day, youre only saving 10 mins a day at the cost of sometimes hundreds of dollars. Also as stated above, Quadros are geared towards "workstation" category machines as you would expect a Vectorworks machine to be included in, but we do not release Quadro-specific drivers like 3DS Max or other software packages do, so they really just aren't worth it. They're significantly more costly, drivers are updated less often, and in general we see better OpenGL performance out of their cheaper, gaming counterparts. Specifically the GeForce GTX 970 series as of the writing of this post if you're going for the best bang for the buck. An SSD (Solid State Drive) is highly recommend, as it makes not only boot up time for your machine much shorter, but makes each little thing your machine does just a bit faster. You will have difficulty quantifying it without running a direct stopwatch comparison between a standard HDD and an SSD, but trust me, you will FEEL the difference in every tiny moment where a machine used to lag behind your input. 16GB of RAM should be more than fine for most uses, but yes in general, the more the merrier, with 24 or 32GB where you will no longer see a return on investment for more. --------------- As a semi-aside to this thread, would you folks find it useful for Tech Support to post an up to date every 6-months-or-so Buyer's Guide for hardware such as graphics cards and CPUs? We generally don't advise specific computer models, since specs change so rapidly we could never keep up, but would specific components and overall recommended specs by us (as an enhancement to the minimum specs we list officially) be desirable? Quote Link to comment
grant_PD Posted December 26, 2014 Share Posted December 26, 2014 Yes to the buyers guide. And please create a benchmarking file that users can use to look at equipment specs. I think users get very confused as to what more ram/ more processing power/ better cards can do. Quote Link to comment
J. Wallace Posted December 26, 2014 Share Posted December 26, 2014 Also a big yes to the Buyer's guide Jim. I'm also on holidays but find it hard not to check this forum every day... Quote Link to comment
Danilo Posted December 27, 2014 Author Share Posted December 27, 2014 Thanks, Grant and Jim. It looks like I am back at the 32GB i7 with 4GB nVIDIA GeForce GTX 745. Since I do not intend to run multiple or super high res monitors it sounds like that GPU should work for me. As for the new monitor, we are looking at a Dell Ultrasharp 27" 2560x1440 LED. Any thoughts? Quote Link to comment
Kizza Posted December 27, 2014 Share Posted December 27, 2014 (edited) I have 2 U2412M Dell 24" Ultrasharp. I am very happy with them. The connectivity is excellent. I also chose the above because I wanted 16:10 ratio (rather than the more common 16:9). 16:10 gives me a slightly taller screen. Edited December 27, 2014 by Kizza Quote Link to comment
Vectorworks, Inc Employee Vectorworks - Admin Posted January 2, 2015 Vectorworks, Inc Employee Share Posted January 2, 2015 Same, love the extra space that comes with 16:10 aspect ratio. However, 2560x1440 at 16:9 should also be just fine. 1080p is starting to get a little cramped and 4k+ is overly taxing on average graphics hardware. Quote Link to comment
Danilo Posted January 2, 2015 Author Share Posted January 2, 2015 Thanks again, all. I really appreciate your feedback. I have decided on this system and plan on confirming the order later today unless someone out there thinks they should talk me out of it. The whole rig with Office 2013 and 3 year hardware warranty is coming in at $2,900 with tax. The vendor is local and trusted so that factored in, too. I searched a couple on-line custom builders (Falcon and Origin) and while I felt I could get a slightly better machine (namely a higher grade GPU) with them, I prefer to keep my dollars local. Dell OptiPlex 9020 Desktop Windows 7 Pro, 64 Bit 32 GB RAM Intel Core i7-4790 (Quad Core, 8MB, 3.60GHz w/HD4600 Graphics) 256GB SSD primary drive (for the OS and software) 1 TB SATA secondary drive (for less used stuff and archiving) DVD +/- RW nVIDIA GeForce GTX 745, 4GB DDR3 27" Dell Utrasharp 2560x1440 U2713HM Quote Link to comment
grant_PD Posted January 3, 2015 Share Posted January 3, 2015 I think you're gonna like that machine. Quote Link to comment
