minotto Posted August 25, 2014 Share Posted August 25, 2014 I'm using the Custom Renderworks option to render a scene with an image prop of a car inside a large garage, but since the car doesn't have any shadows underneath, it appears like it's stuck on the scene as opposed to being in it. Is there a way to control whether an image prop renders with shadows or not? Quote Link to comment
CipesDesign Posted August 25, 2014 Share Posted August 25, 2014 If you have VW Architect (or Designer) why not use one of the realistic Entourage Vehicles? There are some pretty decent cars, trucks, etc. there, all modeled so they cast an accurate shadow. Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted August 26, 2014 Vectorworks, Inc Employee Share Posted August 26, 2014 Depending on the angle, you can sometimes place either an entourage car or a generic 3D geometry block "behind" the image prop in the view you are rendering to give the ground shadow while keeping the same image prop. Quote Link to comment
minotto Posted August 26, 2014 Author Share Posted August 26, 2014 Ok thanks for the suggestions. Quote Link to comment
SonnyLuong Posted August 28, 2014 Share Posted August 28, 2014 Or you can just draw a polyline and attribute it w/ the right color and opacity. You can do that straight in VW or you can do that later in PS if you happen to export your rendered image out to Shop to manipulate it further. Quote Link to comment
steve s Posted September 24, 2014 Share Posted September 24, 2014 how do I make realistic shadows with image prop trees?? Now I have shadows that are crosses orXs depending on the angle. Should I make a new hybrid symbol with a 3d element that will give better shadows? see pic Quote Link to comment
carpalmer Posted September 24, 2014 Share Posted September 24, 2014 for tree shadows I sometimes eliminate the "auto rotate" option for the image prop, and I manually adjust it so that it is close to perpendicular to light source in order to get full shadows. I also sometimes add additional image props out of view (behind camera) in order to obtain shadows on the ground ahead... see attached carpalmer Quote Link to comment
steve s Posted September 25, 2014 Share Posted September 25, 2014 (edited) I cannot find the Auto rotate option, I tried editing Plant, and 2d and 3d symbol. Never Mind I got it by moving the elevation of the light around. Thanks Edited September 25, 2014 by steve s Quote Link to comment
carpalmer Posted September 25, 2014 Share Posted September 25, 2014 click on image prop and then go to Object Info and unclick the auto rotate option... carpalmer Quote Link to comment
steve s Posted September 26, 2014 Share Posted September 26, 2014 (edited) doesn't seem to be auto rotate option on 2015 Oops found it.. thanks Edited September 26, 2014 by steve s Quote Link to comment
