LightGuy145 Posted August 8, 2014 Share Posted August 8, 2014 If I draw a rectangle and a line that crosses through it and then try to move another object to the intersection between that rectangle and line I have no problem using the "Snap to Intersection" feature. If I take said rectangle and extrude it I suddenly lose the ability to "Snap to Intersection" between the 2D rectangular representation of the extrude and the line. This makes it extremely difficult to do basic alignment of extrudes with lines or even extrudes with one another. All objects in question are on the same layer and class, layers and classes are set to "Show/Snap/Modify Others". Nearly all snap options are turned on. Working in 2D/Plan view. Am I missing something here? I feel that this has not always been the case. I am running VW 2013 SP5. Quote Link to comment
LightGuy145 Posted August 19, 2014 Author Share Posted August 19, 2014 Has no one else experienced this problem or has it been resolved in VW 2014? Quote Link to comment
bc Posted August 19, 2014 Share Posted August 19, 2014 Doesn't appear to work in 2014. Quote Link to comment
Kevin McAllister Posted August 19, 2014 Share Posted August 19, 2014 Unfortunately its never worked as far as I know. Lots of people draw using lines as guides so this is a big weakness of VW. Kevin Quote Link to comment
Bruce Kieffer Posted August 19, 2014 Share Posted August 19, 2014 This points out our need to have Vectorworks see what we see. You have a 2D and 3D object, yet in your screen view they both appear as 2D (a rectangle and a line), and you want to snap to them, but Vectorworks can't figure it out. Quote Link to comment
LightGuy145 Posted August 28, 2014 Author Share Posted August 28, 2014 I opened VectorWorks 12.5 in Windows XP Mode this morning and you can't snap to an Object/Object intersection between an extrude and a 2D shape in that version either. This does seem like a rather simple thing that you should be able to do. Otherwise you have to create extra temporary reference lines in order to achieve the desired snaps. Quote Link to comment
