bcd Posted December 21, 2013 Share Posted December 21, 2013 Should the Eyedropper>Viewport Attributes>Other Properties be expanded to allow selection of only Render Settings? Currently it's a catch-all for Render Settings, View, Scale ... I'm trying to simply transfer the Render settings from one Viewport to another. another option would be to provide a: New Renderworks Style from Current Viewport command. I'm missing the obvious amn't I? Quote Link to comment
Kevin McAllister Posted December 21, 2013 Share Posted December 21, 2013 I'm not sure that you're missing anything. There was a recent wish to separate the Render Settings from the View and Scale when using the Eyedropper since they are currently linked. I know Jim submitted it. I often option drag to copy viewports and then reset the view, but that can be hard to do if its a section or perspective viewport. Kevin Quote Link to comment
grant_PD Posted December 21, 2013 Share Posted December 21, 2013 I would like all viewports to have a customizable, default setting. I would like to be able to select viewports en masse and change their render settings. Quote Link to comment
billtheia Posted December 23, 2013 Share Posted December 23, 2013 I would love for the eye dropper tol to be able to grab just the render settings. In the mean time, use of render styles will get you very close to the same result. Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted December 23, 2013 Vectorworks, Inc Employee Share Posted December 23, 2013 Yup, this was submitted recently. I'll add this thread to it. Quote Link to comment
