WhoCanDo Posted September 12, 2013 Share Posted September 12, 2013 Hi, Just installed Microsoft's Office 365 we based software and Vectorworks 2012 has stopped working with: Problem signature: Problem Event Name: BEX Application Name: VECTOR~1.EXE Application Version: 17.0.5.0 Application Timestamp: 50379bde Fault Module Name: StackHash_4c0d Fault Module Version: 0.0.0.0 Fault Module Timestamp: 00000000 Exception Offset: 00000000 Exception Code: c0000005 Exception Data: 00000008 OS Version: 6.1.7601.2.1.0.256.48 Locale ID: 3081 Additional Information 1: 4c0d Additional Information 2: 4c0d4d78887f76d971d5d00f1f20a433 Additional Information 3: 4c0d Additional Information 4: 4c0d4d78887f76d971d5d00f1f20a433 Anyone else had problems with Office 365? Quote Link to comment
Robert Anderson Posted September 12, 2013 Share Posted September 12, 2013 We use Office 365 here at Nemetschek Vectorworks. I recommend you call Tech Support. Quote Link to comment
Administrator JuanP Posted September 12, 2013 Administrator Share Posted September 12, 2013 Make sure you have the latest 2012 SP available from: http://www.vectorworks.net/downloads/index.php If the SP does not fix your issue. tech@vectorworks.net Quote Link to comment
WhoCanDo Posted September 17, 2013 Author Share Posted September 17, 2013 Just to keep you updated on the Office 365 vs Vectorworks 2012 problem, I waited a day and a bit for Microsoft to ring me before trying this: From the start menu I right clicked on Vectorworks and chose ?Troubleshoot Compatibility?. After going thought the steps VW 2012 works again with a few weird happenings. First, most of my pallets have a black boarder. Secondly my snapping pallet (which is the only one that doesn't have a black boarder) doesn't stay in the 2 x wide, 4 x deep format after I close and re-open VW. I can put up with the weirdness since VW still works. Thanks for the suggestions. Quote Link to comment
WhoCanDo Posted September 18, 2013 Author Share Posted September 18, 2013 I just found that compatibility mode was reset to Win'XP SP1 so I fiddled a bit and found Win'Vista SP2 is a better option. Compatibility is found when you right click on the start bar icon of VW (or any shortcut) and choose properties and then the compatibility tab. Quote Link to comment
Roly Eguez Posted November 10, 2017 Share Posted November 10, 2017 On 9/12/2013 at 2:53 PM, JuanP said: Make sure you have the latest 2012 SP available from: http://www.vectorworks.net/downloads/index.php If the SP does not fix your issue. tech@vectorworks.net Dear Far friend your address doesn´t work, show me this Quote Link to comment
Roly Eguez Posted November 10, 2017 Share Posted November 10, 2017 On 9/17/2013 at 8:00 PM, WhoCanDo said: I just found that compatibility mode was reset to Win'XP SP1 so I fiddled a bit and found Win'Vista SP2 is a better option. Compatibility is found when you right click on the start bar icon of VW (or any shortcut) and choose properties and then the compatibility tab. Dear far friend.. I do the same, i used windows compatability " Windows Vista SP2".. and it WORKS great. FIXED..!!! i was trying to find and answer, i even reinstall my windows 7, .. i erase my hard disk with active killdisk, and install windows... but using "Windows Vista SP2" fixed .. resolved, thanks a lot.. I would like to know why it happens.. i had a Portatil computer, a laptop, with Windows 7 original from factory, is an HP Elite Book 8560w and no problem with this.. I had prolem with the one that i reinstalled windows? that are different version of windows 7??? even profesional windows? Does anyone knows why? thanks a lot Roly Eguez fb /rolyeguez rolyeguez@gmail.com Quote Link to comment
MullinRJ Posted November 11, 2017 Share Posted November 11, 2017 On 11/10/2017 at 6:33 AM, Roly Eguez said: Dear Far friend your address doesn´t work, ... Roly, Try this link instead: http://www.vectorworks.net/support/downloads/product-updates HTH, Raymond Quote Link to comment
