Ran Posted January 8, 2013 Share Posted January 8, 2013 (edited) I recently recalculated my plant schedule report. The new plants were added to the list but so too was the following unwanted row in between my other plant rows: ID 0 Latin Name Common Name Notes How do you you remove this? I have spent hours trying to work out why it appears and how to remove it to no avail. Please help. Ran Edited January 8, 2013 by Ran Quote Link to comment
Ozzie Posted January 8, 2013 Share Posted January 8, 2013 Hey Ran, I have had this problem also, What OS and VW version are you using? May help if you include that info in your signature My Stuff above Quote Link to comment
Ran Posted January 8, 2013 Author Share Posted January 8, 2013 Hi Ozzie, Thanks for the tip. I'm using VW 2012 on Mac Lion. Quote Link to comment
Ozzie Posted January 9, 2013 Share Posted January 9, 2013 (edited) Hi Ran, I have had this happen also as per below Can you upload file here even if it is stripped back to plants only for others to look at? Or use Dropbox or similar Edited January 9, 2013 by Ozzie Quote Link to comment
Jonathan Pickup Posted January 9, 2013 Share Posted January 9, 2013 that row that you don't want is a plant, you just have to find it and delete it. try right clicking on the row, do you get select item? Quote Link to comment
Ran Posted January 9, 2013 Author Share Posted January 9, 2013 Select item is greyed out. Quote Link to comment
Jonathan Pickup Posted January 9, 2013 Share Posted January 9, 2013 send me the file jon@archoncad.co.nz let me have a look at it Quote Link to comment
Ran Posted January 9, 2013 Author Share Posted January 9, 2013 Thanks for offering to look at the file Jonathan but it is a student version. It was suggested that I put my landscape areas onto a different class from my plants and changed the schedule's paste criteria to list objects whose class is not that of the new class. Issue resolved. Quote Link to comment
Vectorworks, Inc Employee Tamsin Slatter Posted January 9, 2013 Vectorworks, Inc Employee Share Posted January 9, 2013 I'm glad I was able to resolve it Ran. I knew I had seen the problem before but it took me a short while to remember what caused the problem. The issue is that there is an extra plant record present in the file attached to the Landscape Area itself. If you place the Landscape Area into a different class from the plants themselves, and then exclude that class from the selection criteria for the worksheet, the extra row is removed from the results. All the best Quote Link to comment
