VincentCuclair Posted November 26, 2012 Share Posted November 26, 2012 (edited) I would like an extra option in the Saved Views dialog that makes it possible to save specific Heliodon settings. Edited November 26, 2012 by Vincent C Quote Link to comment
0 line-weight Posted August 9, 2016 Share Posted August 9, 2016 +1 for this. It would be useful to be able to save views of different parts of a building with the heliodon settings adjusted for each to give desired results for renderings, instead of having to change the heliodon settings manually each time you switch between views. Quote Link to comment
0 zoomer Posted August 9, 2016 Share Posted August 9, 2016 It doesn't switch automatically too but you can create as much heliodons as you want and activate one at a time in light lister. At least easier than edit changes all the time in one Heliodon. Quote Link to comment
0 line-weight Posted August 9, 2016 Share Posted August 9, 2016 It doesn't switch automatically too but you can create as much heliodons as you want and activate one at a time in light lister. At least easier than edit changes all the time in one Heliodon. Good point. Quote Link to comment
0 ericjhberg Posted August 9, 2016 Share Posted August 9, 2016 I agree. Heliodon settings should be per viewport. On a similar note, I actually think the Heliodon should be automatically integrated into your document settings. I don't know of a world where the sun does't exist. Having to place a heliodon every time just creates one more item to lose track of. If it were in the document settings, then the master controls for location would be real-world document based and separate controls for time of day would be part of the viewport characteristics. Quote Link to comment
0 Gilbert Osmond Posted August 9, 2016 Share Posted August 9, 2016 (edited) I agree. Heliodon settings should be per viewport. On a similar note, I actually think the Heliodon should be automatically integrated into your document settings. I don't know of a world where the sun does't exist. Having to place a heliodon every time just creates one more item to lose track of. If it were in the document settings, then the master controls for location would be real-world document based and separate controls for time of day would be part of the viewport characteristics. Certainly agree that there should be per-viewport settings for a single heliodon instance, instead of having to do multiple heliodons & control them by class visiblity. Edit: oops, there IS a way to handle this, on the Lighting panel. As far as document-level heliodon, it'd streamline some projects to have a master heliodon location but if that was added as a feature it is important to be able to override it on a per-viewport / per-sheet basis. Think about the case where, for instance, you are designing a standardized building that will be used in different parts of the country / world, & you want to conveniently render it at different latitudes. Would not be fun to have to create separate documents & use linked viewports / layers to achieve that. The current free-form heliodon system handles this use case easily. Perhaps another option would be to expand the Heliodon tool settings w/ a checkbox or menu-drop down to designate a heliodon instance as "the master heliodon" for the document. As mentioned above, on the Viewport settings there could be a Heliodon date/time field that would set the viewport's date & time for that master heliodon. If there were multiple heliodons, those could be given names, & then any one of those named heliodons could be selected in the viewport's drop-down menu, i.e. to pick the desired location. Edited August 9, 2016 by Gilbert Osmond Quote Link to comment
0 zoomer Posted August 9, 2016 Share Posted August 9, 2016 & control them by class visiblity. Hey, there is an automation this way Quote Link to comment
0 zoomer Posted August 9, 2016 Share Posted August 9, 2016 Ok, when looking at some of my VP with different Top Plan Views I also would like to use different sun angles. So I +1 too. Location as document setting, north direction maybe too. That's what will be default when you create a new Heliodon. And an option in VP setting to overwrite Helios time, date and north direction Quote Link to comment
0 line-weight Posted August 10, 2016 Share Posted August 10, 2016 Heliodon as document setting makes sense to me too. It's counterintuitive to have it as an object which you have to place in the drawing. Given that it doesn't make any difference where you place it, it's weird to have to place it "somewhere". Quote Link to comment
0 zoomer Posted August 10, 2016 Share Posted August 10, 2016 And it is in the way all the time. If you make it invisible by class/layer it will have no light. If you make it visible but non editable you will see it anyway and very likely overwrite that class/layer setting while working with these. Quote Link to comment
VincentCuclair
Edited by Vincent CLink to comment
9 answers to this question
