jnr Posted April 29, 2002 Share Posted April 29, 2002 I've been using this program for a long time and have never taken the time to figure out how to have it open without defaulting to a blank document. Is this a windows issue or a vectorworks issue? Win 2000 9.5.1 w/architect Quote Link to comment
CipesDesign Posted April 29, 2002 Share Posted April 29, 2002 JNR, you know what they say: "The only stupid question is the one you never ask." But on a scale of 1 to 10.... OKAY, here's what you do: open a blank document and change all of the settings (page size, type face, line weights, origin, etc. etc. ad infinitum) to what you like. On mine I have a tiltle block on it's own layer and many other "standard" layers already defined. THEN save the that document "as a template". Then when you want to start a new job, simply open the template, which will give you an untitled new document with all of your defaults already set. PLC Quote Link to comment
jnr Posted April 29, 2002 Author Share Posted April 29, 2002 Cipes: Thanks for the heads up. Its been years since I fumbled around with templates. Sounds like I may need to re-visit. Since I work on different projects during the day, I was hoping to simply open the program without defaulting to any file. I was hoping for tabula rasa, able to open files needed, not always quiting the blank file already open as my first move everyday... Kind of like Quark, Photoshop, Acrobat etc, which open without opening a blank file or template. Quote Link to comment
CipesDesign Posted April 30, 2002 Share Posted April 30, 2002 I'm not sure, but I bet you could write a little start-up script for you OS that opened certain app's but no doc's. PLC Quote Link to comment
Joe Newell Posted April 30, 2002 Share Posted April 30, 2002 Why don't you just open Vectorworks by clicking on the file you want to open? Or maybe that's a stupid answer. Quote Link to comment
jnr Posted April 30, 2002 Author Share Posted April 30, 2002 That would be the easy answer if win 2000 didn't get so confused when it can't figure out which application version to open it with. Open with 9.0? 9.01? 9.5? 9.51? NNA has left carnage all over my hard drive by copying program folders, so its a little tough for the OS to figure out what to do. Especially since NNA does not recommend blowing away the next to the latest version of the program. Quote Link to comment
Kevin Posted April 30, 2002 Share Posted April 30, 2002 Does anyone know if it is possible to increase the number of "last used" documents in the File menu. When I click on the File menu I am presented with the last 4 documents that I used. Quote Link to comment
Vectorworks, Inc Employee Andrew Bell@NV Posted May 1, 2002 Vectorworks, Inc Employee Share Posted May 1, 2002 quote: Originally posted by Kevin: Does anyone know if it is possible to increase the number of "last used" documents in the File menu. When I click on the File menu I am presented with the last 4 documents that I used. It is not possible to increase the size of that list in VectorWorks 9. Quote Link to comment
