James Russell Posted June 30, 2011 Share Posted June 30, 2011 Hey all, Just got back to my computer. Tackled a small thing I've been working on. Wrote this: =concat(min(height,width,(volume/height/width)),' x ',volume/min(height,width,(volume/height/width))/max(height,width,(volume/height/width)),' x ',max(height,width,(volume/height/width))) Which I inserted into a database row with the criteria of type is extrude. It's basically my attempt thus far at creating a cutting list for a whole series of flats in 3D. The only thing is when I press enter the formula works and returns the result required but the formula itself disappears. The reason for it being in all one formula is that when it is dependant on previous cells and is summarised to get the total cuts of each length type the values all change because they are numbers. I just found it interesting and thought I'd share. J Quote Link to comment
Pat Stanford Posted June 30, 2011 Share Posted June 30, 2011 You should be able to work around it by putting something into the concat that will make it work as text rather than strictly numbers. Can you try putting an underscore or maybe even a space into the formula? If you can post the file containing the worksheet I can take a look when I get back. Quote Link to comment
James Russell Posted June 30, 2011 Author Share Posted June 30, 2011 Attached is my current test file. The new formula works thus far. I'm going to continue working on it today. I know I've seen a few posts relating to similar ideas of cut list / material calcs. I'll keep plugging away and let you know if I find anything. Cheers, J Quote Link to comment
Pat Stanford Posted July 1, 2011 Share Posted July 1, 2011 It is very strange. It appears that the worksheet engine is interpreting the contacts prior to showing the formula in the database header cell, but is using the formula correctly in the item sub rows. You can see this even with a simpler formula. Type =Min(Hight,Width) into a cell and hit enter. When you click back into the cell to check the formula, it has changes to =width. I will bugsubmit this. Quote Link to comment
