Hello Community!
This Thursday, October 21st, from 6 pm to 7 pm EDT, we will be performing an update on the Vectorworks Community Board. During this time, the site will be unavailable.
How amend multiple marker styles?
I have a plan with some 30 windows (PIO Windows). All are on a schedule and have their ID tags visible. I have placed them all and have leaders etc.
Now, I would like to select them all and add a marker to the leader. However, this only seems possible on a individual basis - i.e. I will have to select each window one at a time and change the marker style settings.
I tried creating a worksheet to do this, but the marker style is not available as a data string.
Anyone got any ideas?
Cheers.
I think mgj is trying to change the marker style, which, even in 2011, is only possible through "Settings" - not directly from the OIP or attributes palette.
And I'm pretty sure you can't select multiple windows and go into settings.
I couldn't find a worksheet solution either. Sounds like a job for the Vectorscript gurus.
mk
Sorry MK, but there does seem to be a worksheet solution in VW2011.
'window'.'usemarker' gets the marker status
'Window'.'MarkerStyle' is an integer for the marker style
'Window'.'MarkerAngle' the angle of the marker
'Window'.'MarkerSize' the size of the marker.
I have not tried these back in VW2008.
These came from the script at:
http://techboard.vectorworks.net/ubbthreads.php?ubb=showflat&Number=108487#Post108487
The original version should run in VW2008, but it won't have all the latest enhancements.
The latest version is December of 2008, you might have it.
I was just playing with this and noticed that in the worksheet you get the pull-down choices in the data bar for data types that have a limited enumeration. For instance if you have a cell showing the ID box shape, when you click in a cell you get a pull down in the field you would normally type into that shown the possible choices.
Pretty neat.
