bcd
Brushed Aluminum
Has anyone had any success using this texture? No matter what I try I cannot get the Brushed Aluminum to look anything like its namesake.
I've resorted to importing an image Color and using the metallic settings. This works well enough- but the Brushed Pattern in the Reflectivity>Metallic dialogue does nothing perceptible for me.
Nope, I spent a while trying to get it to look something good but gave up.
Perhaps the Brushed pattern is broken.
Edited by bcd
Have you tried using Turned instead of Brushed within the Metallic reflectivity shader?
An alternative is to use a stretched noise shader within the Color shader - increase the value of the Relative U% to something like 2000 and reduce the Relative V% to something like 10. This will stretch the pattern to a similar effect, but you do get a seam where the texture maps on the surface and I've been unable to get rid of this...
Thanks Tamsin,
I ran a Gradient>Noise>Blur in photoshop to create a decent Image to use as the color. Setting the size big enough means, for my elements, I don't have the tiling issue.
I'll try your method too. Sounds promising.
Perhaps NV can tell us if it's working correctly. I'd expect the scaling option to be available in the OIP if it were.
Control over specularity would be good too. I'm finding some of these texture shaders to be lacking in options.
