Assemblage Posted February 3, 2010 Share Posted February 3, 2010 Curious to know how people are building their models.. Sheet layer VP's showing plans modelled using walls and plug-ins etc on design layers with appropriate Z values still show the full height and detail of 3D modelled elements. Eg, a downpipe made using extrude along path appears with all it's upper branches etc on the floor plan, when a simple circle is all that is required at that point. Are people creating many hybrid symbols for this? Is it possible to limit the cut of a plan (like a section viewport)? P Quote Link to comment
CipesDesign Posted February 3, 2010 Share Posted February 3, 2010 1) Yes, sheet layer VP's; 2) Either put those objects into their own discreet class and annotate for each plan VP or create hybrid symbol; 3) Not possible (maybe someday?) Quote Link to comment
michaelk Posted February 3, 2010 Share Posted February 3, 2010 (edited) Is it possible to limit the cut of a plan (like a section viewport)? Yes. Sort of. (If I understand what your asking....) Create a SLVP in front view. Create a section SLVP from that. michaelk Edit: Forgot to turn on "save viewport cache". Update all the VPs and it will make sense. Edited February 3, 2010 by michaelk Quote Link to comment
domer1322 Posted February 3, 2010 Share Posted February 3, 2010 please elaborate ... is a SLVP a "section line view port" ? When I try to place a section line on a front view, it immediately flips the view to "top plan" as soon as I click on the section line button so i can't draw the section line across the front view. Is there antoher way to draw the section line ? Quote Link to comment
Vectorworks, Inc Employee Robert Anderson Posted February 3, 2010 Vectorworks, Inc Employee Share Posted February 3, 2010 Domer, by "SLVP", Michael means "Sheet Layer Viewport". If you want a "true 3D cut plan", the way to get it is to draw your model, create an elevation view port on a sheet layer, then enter the notation group of the viewport, and draw a section line there (looking down, in a -Z direction). The section viewport created will be a 'true plan cut'. Quote Link to comment
Assemblage Posted February 3, 2010 Author Share Posted February 3, 2010 Spun out: "Create a Sheet Layer Viewport in front view. Create a Section Line Viewport from that" Seems to work - thanks michaelk Quote Link to comment
michaelk Posted February 3, 2010 Share Posted February 3, 2010 I'll attach a 2009 version. The only real trick is that I made VP #4 on a sheet layer, selected it, then View>Create Section Viewport..., and in Advanced Section Properties set the depth range to Finite, 10' - 0". Of course, there's no need to set the depth when creating the viewport, that can be done later. And I skip Robert's 3rd step, entering the annotation group of the viewport. It seems to figure out what I mean by just selecting the VP. hth michaelk Quote Link to comment
domer1322 Posted February 3, 2010 Share Posted February 3, 2010 OK ... I got it ... Cool feature. I learned something today thanks to your help. (that doesn't happen every day). Quote Link to comment
CipesDesign Posted February 3, 2010 Share Posted February 3, 2010 Yes, thanks RA, I had forgotten we could do that...Glad you clicked in. P Quote Link to comment
