Best Things About 2010
3D snapping is much better and makes alot of difference when working in 3D. I can actually move objects around my design and locate them without having to line things up in one view and then switch to another view to line them up in that plane.
But the best improvement from my point of view is the Working Planes. They are easier to set and use. I don't get 3 'cycling' views if I select the same view 3 times and it is much easier to extrude on the working plane. I can even rotate the working plane by dragging it!!!
PIO, namely nuts and bolts, still don't align themselves to the working plane though.
