billgore Posted July 16, 2009 Share Posted July 16, 2009 I got a project and I need to model some very large open web steel trusses does any one have a suggestion on the best way to do these. Quote Link to comment
MattG Posted July 16, 2009 Share Posted July 16, 2009 What do you have that you are staring from? Is it a picture? Maybe some specs? The best way is to get them to send you a model of it, but I am guessing that is not an option. I will some times get building drawings in 2d and want to create 3d models for a rendering. I will often find that there are i beams that go into the ground and extend up to a grid I can compose the lines making that up and extrude them along where the grid would be and it is pretty close. Quote Link to comment
Jeffrey W Ouellette Posted July 16, 2009 Share Posted July 16, 2009 The Framing Member tool (Architect and Designer) does this. Also, please don't multi-/cross post questions. One post in one forum is enough. Quote Link to comment
cad@sggsa Posted July 17, 2009 Share Posted July 17, 2009 Good day billgore I find it best to import an AC file to VW which indicates the side view of siad truss. Trace blocks and extrude. As MattG mentioned they are mostly I-beams. Normally all the beams are the same size and height. working from the plan view you determine the distance between beams/truss. I unfortunatly have the task of drawing up the CTICC Exhibition halls. In one hall not one beam is at the same height and they do have different sizes in each hall. Oh and they are curved. Good luck Quote Link to comment
doday Posted August 8, 2009 Share Posted August 8, 2009 I have the same question. I have a 2d iso, top and side dwg that I want to recreate on 3d. It's a steel based dome stage. What's the best way to draw it? From scratch by tracing or by extrudes? How would I do the latter? Thanks Quote Link to comment
mike m oz Posted August 8, 2009 Share Posted August 8, 2009 If the truss is made of rectangular sections: - Switch to a true side on view and trace the shapes of the members. - Give each shape a fill and then Extrude each one by its width. - Switch to a top view and move the chord members so they are central to the top and bottom chord members. - Draw a dashed line on the centreline of the truss. - Select the line and all of the 3D parts and create a hybrid symbol of it. Note: Best to do this in a separate file. Quote Link to comment
doday Posted August 8, 2009 Share Posted August 8, 2009 (edited) Edit - Fixed it... Q: Rotate truss tool truss? A: Ungroup>Group>Edit Group>Rotate Edited August 8, 2009 by doday Quote Link to comment
