nakedeye Posted March 4, 2009 Share Posted March 4, 2009 I've set up a worksheet in spotlight with columns for channel, fixture etc. and selected to sort via channel, however as some channels are single digit - 1,2,3 and some are 3 digits..101 etc the list when sorted goes 1,101,102,2,3,301,302 etc. is there anyway i can get it to list in numerical order? so it would go 1 thru 99 then 100 onwards? i've looked in format cells and tried various number options with no luck. Quote Link to comment
michaelk Posted March 4, 2009 Share Posted March 4, 2009 Believe it or not, the Channel field is a text field. There is another field, called "Alt-Chan" that is (if I understand correctly) generated from the Channel Field. Add this field to your worksheet and use it for sorting. I usually put it way to the right and make the column so skinny I can't see it. I suppose you could use Alt-Chan in place of Channel, but back in the old days (v10) I ran into trouble trying to change the Alt-Chan field. I don't know if this still applies. hth michaelk Quote Link to comment
Vectorworks, Inc Employee klinzey Posted March 5, 2009 Vectorworks, Inc Employee Share Posted March 5, 2009 The alt- fields are still text fileds they just have zeros prepended to the number. And if you cange the values they will not update the filed. You can also use =VALUE('Lighting Device'.'Channel') this will convert the text to a number and sort correctly but it will disable editing. Quote Link to comment
michaelk Posted March 5, 2009 Share Posted March 5, 2009 Kevin You're working late tonight. The =Value is a great tip. Thanks! michaelk Quote Link to comment
nakedeye Posted March 5, 2009 Author Share Posted March 5, 2009 Tanks for the help guys, i'll give it a go max Quote Link to comment
