G_Cliff Posted November 5, 2008 Share Posted November 5, 2008 I am using VW 11.5 and have taught myself how to use it using manuals, tutorials, and online help. I have started using Spotlight in creating my light plots but have run into a problem. When I try to click "Label Legend Manager" to make a legend and assign a label legend to a fixture, nothing happens. No window pops up saying "add" or "edit". Nothing. What am I doing wrong. Thanks G Cliff Quote Link to comment
MrTemplate Posted November 11, 2008 Share Posted November 11, 2008 hello G Cliff; i have an old copy of 11.5. i'm currently on mac OS 10.5.5, perhaps the app is too old? anyway, i just attempted to dupe your sequence; i opened a doc, i selected spotlight>instrument processing>label legend manager, and the label legend manager window properly appeared. i added a new label called 'shelley'. in the 'add new legend' window i double-clicked on unit number, color, channel, and purpose. i clicked ok, i then clicked on 'edit layout'; i edited and clicked ok. i then selected 'shelley' from the resource browser and edited it some more. no problem. i then made a fresnel symbol active in the RB, inserted it into the drawing using the spotlight instrument insertion tool, and assigned the label legend. no problem. then i inserted the same fresnel into the drawing using the 2d symbol insertion tool, convert to instrument, assign label legend. no problem. does this help at all? hope so, shelley Quote Link to comment
G_Cliff Posted November 14, 2008 Author Share Posted November 14, 2008 Thanks for trying. I don't know what is wrong. Does any tool or object have to be selected to make the manager work? Thanks, G Quote Link to comment
MrTemplate Posted November 15, 2008 Share Posted November 15, 2008 Hello G: you need to have a lighting device selected before you can invoke the "assign Legend to Inst". are you certain that you are selecting lighting devices and not just 2d symbols? regardless, it sounds like you need to get to someone else who knows spotlight and watch them on the screen. or send your file to tech support? good luck, shelley Quote Link to comment
JSagona Posted November 15, 2008 Share Posted November 15, 2008 G- I am having exactly the same issue. Whenever I go to Spotlight > Instrument Processing > Label Legend Manager absolutely nothing happens at all. No pop up window, no options... I also have the issue with Spotlight > Utilities > Key to Instrumentation. Could it have something to do with the setup of the file from the start? I know I didn't used to have this problem a year ago and I am not certain when it creeped up. Quote Link to comment
MrTemplate Posted November 17, 2008 Share Posted November 17, 2008 hello jim; Yikes! i've not experienced what you're seeing (knocking madly on anything resembling wood). this sounds like a job for tech support. good luck, shelley Quote Link to comment
pscbimmer Posted December 8, 2008 Share Posted December 8, 2008 (edited) I seem to be having similar issues, but I though it was just with making light positions. Since reading this post I've tried some other things out and I get nothing for label legend manager, assign label legend, and it seems the rest of the other options under "spotlight" aren't working either. Edited December 8, 2008 by pscbimmer Quote Link to comment
Nik Posted December 12, 2008 Share Posted December 12, 2008 Sounds like your workspace or plug-ins folder might have been corrupted. Try switching to a different workspace and then back to the Spotlight workspace. If that doesn't work try reinstalling VW. Quote Link to comment
pscbimmer Posted December 15, 2008 Share Posted December 15, 2008 Sounds like your workspace or plug-ins folder might have been corrupted. Try switching to a different workspace and then back to the Spotlight workspace. If that doesn't work try reinstalling VW. Thanks for the suggestion, but none of that solved the issue. I switched workspaces, I uninstalled then reinstalled, and I also tried a reinstall after uninstalling then deleting the vectorworks and nemetschek folders in the registry. For now since I have some basic drafting to do asap I had to find and install my old VW 9.5 and that is working as expected. Quote Link to comment
Sam Jones Posted December 21, 2008 Share Posted December 21, 2008 This came up on the user list. How many fonts do you have installed? I'm not sure where the threshold is, but you may need to drop the number of fonts you have installed to below 250. Quote Link to comment
Jen Corman Posted January 11, 2009 Share Posted January 11, 2009 I had this problem and resolved it by uninstalling the latest Quicktime and reinstalling version 6.5.1 which is the version that the updates wanted Quote Link to comment
G_Cliff Posted January 13, 2009 Author Share Posted January 13, 2009 Dear Jen, Thank you, thank you, thank you. You have saved me. I wasn't sure what to do next. But thanks to your quick post and simple fix, it now works. Now I just have to learn how to use it. Ever greatful, G Quote Link to comment
pscbimmer Posted March 13, 2009 Share Posted March 13, 2009 (edited) I had this problem and resolved it by uninstalling the latest Quicktime and reinstalling version 6.5.1 which is the version that the updates wanted That was my problem too.I figured this out because my HD died and I had to reinstall my programs. When I started up VW I got a warning that the version of quicktime I was using was not the same one that shipped with VW, and that if there were functionality issues to install the version that came on the cd (6.5.1). I installed 6.5.2 and all the functionality returned. Edited March 13, 2009 by pscbimmer Quote Link to comment
