kgroob 3 Posted October 29, 2008 (edited) I have a 24 mb size 3d renderworks file that I can't print. It doesn't do me much good to make this detailed model if I can't print it. I tried reducing the resolution to 72 dpi, changing 3d conversion to medium, rendering in open GL, and that didn't work. Then I tried printing to a PDF first, and that didn't work. Then I tried rendering a portion of the model as a bitmap in Open GL at 72 dpi, and that didn't work. Finally I had to resort to a screen shot, which worked. The model uses extrudes, extrude along paths, sweeps, and symbols. My Mac has 1 GB of memory, which I'm guessing is not enough. How much memory is needed on the computer and/or plotter in order to print a file like mine? Is it as simple as buying more memory and plopping it into the hard drive? Edited October 29, 2008 by kriegs Quote Share this post Link to post
gmm18 0 Posted October 29, 2008 I don't know the answer, I am sure someone will chime in soon, but that is a really cool screenshot! Quote Share this post Link to post
Dave Donley 251 Posted October 29, 2008 Hello kriegs: What is the design layer scale set to? Where does the page boundary go if you do a fit to page? You might try creating a viewport as they are a more controlled environment for printing than printing directly from a design layer. Quote Share this post Link to post
kgroob 3 Posted October 29, 2008 The design layer is set at 1/8=1'-0". The page boundary is set as tabloid, 125%, so it hugs the image. I'll try a viewport. Thanks. Also, in doing some research, I noticed a lot of people have recommended using Artlantis. Any experience with that software? Quote Share this post Link to post
D Wood 1 Posted October 29, 2008 My Mac has 1 GB of memory, which I'm guessing is not enough. How much memory is needed on the computer and/or plotter in order to print a file like mine? Is it as simple as buying more memory and plopping it into the hard drive? It depends on your Mac - it may have room for an additional module(s) or you may be able to replace your existing module with say a 2GB. But they plug into slots inside the machine, they have nothing to do with the hard drive. Perhaps you should check with your Mac supplier to see what can be done with your particular Mac - it may be that the cost to upgrade makes a new machine feasible. When you upgrade beyond VW11.5, you will need more memory (at least 2GB, 4GB better), especially for high end renders like your gorgeous illustration. Quote Share this post Link to post
kgroob 3 Posted October 29, 2008 Thanks, D Wood. I'll look into that. Quote Share this post Link to post
M.CH 0 Posted October 29, 2008 My Mac has 1 GB of memory, which I'm guessing is not enough. How much memory is needed on the computer and/or plotter in order to print a file like mine? You dont say what computer you are using. If you save it as a pdf, which is how macs print anyway, might be the route forward. You will then have a file that does not need rendering prior to printing. I was producing stage sets on VW11.5 I was rendering and animating 40mx30m stages with 1000seats on a g4 powerbook with 1g of ram if I remember correctly. Quote Share this post Link to post
kgroob 3 Posted October 30, 2008 I tried printing to PDF after it wouldn't print normally. Vectorworks just kept crashing. Quote Share this post Link to post
D Wood 1 Posted October 31, 2008 Try some Mac maintenance - my apologies if you already know these ....... 1. Restart (I guess you've done that). 2. Run Utilities>Disk Utility>Repair Disk Permissions. 3. Leave your Mac on overnight, or download a program called MacJanitor and run it weekly. 4. Buy a program called DiskWarrior and run it weekly. HTH. Quote Share this post Link to post
Dave Donley 251 Posted October 31, 2008 Hello kriegs: Please send me the file as it is too hard to guess what might be going wrong here. Quote Share this post Link to post
