C W Posted June 2, 2008 Share Posted June 2, 2008 (edited) The other day I was drafting when I realized ALL of the walls had become unjoined. I did the obvious and tried "undo" but no dice. Also, I know I came across this another time but figured it was an anomaly... apparently not. Has anyone else experienced this? Is there possibly a shortcut commend that does this? Is there anyway to correct this scenario without going back and manually reconnecting the walls... which is what did in this case? Thanks Edited June 2, 2008 by C W Quote Link to comment
mike m oz Posted June 2, 2008 Share Posted June 2, 2008 (edited) Were you using Space Objects in the 'paint bucket mode'? If all of your walls aren't joined properly and you click Yes to the dialog box that comes up with an option to update the joins between walls it will actually unjoin them. Possible Fix: Try selecting all of your walls and use the Move tool to move them 25 mm or 1". This may fix the joins. Repeat this move in the reverse direction to get the walls back into their original locations. Edited June 2, 2008 by mike m oz Quote Link to comment
M.CH Posted June 2, 2008 Share Posted June 2, 2008 Have you in your preferences selected Auto Join Walls. Its found in Tools>Options>VW Preferences>Edit> Select Auto Join Walls HTH Quote Link to comment
Christiaan Posted June 3, 2008 Share Posted June 3, 2008 Wall joins, particularly component joins, will disconnect if you edit the Wall Style. Very annoying. Quote Link to comment
C W Posted June 3, 2008 Author Share Posted June 3, 2008 Actually, everything you guys mentioned are aspects of the program I'm constantly both working with and editing/changing. I guess I'll have to be more mindful of what I was doing last in case it happens again. Thanks. Quote Link to comment
