Jim Posted April 19, 2000 Share Posted April 19, 2000 I have files set up with drawings positioned for plotting out on A1 size paper. Sometimes I wish to print out or fax small areas of the drawing on A4 size paper. This involves moving the print area. How can I reposition the A1 print area EXACTLY back to the original default position after having moved it for printing the smaller area of the drawing? Quote Link to comment
MikeB Posted April 19, 2000 Share Posted April 19, 2000 We have this problem all the time. Unfortunately the print area seems to be related to the paste in place command, the alignment of 3-D objects in different layers, and the workgroup referencing. It would be better if these items were only related to the page origion and not the position of the print area. Anyway we haven't found a way to do what your asking. The undo command does not work, and neither does the saved sheets. I hope Diehlgraphsoft either knows something I don't or they are going to fix this. Its really annoying. Quote Link to comment
RGyori Posted April 19, 2000 Share Posted April 19, 2000 One work-around is to make sure you have the document the way wish for normal use, save it, then position the sheet outline for printing. When done, use the "Revert to Saved" command in the File menu. Awkward, but I know of no other practical method. Quote Link to comment
doug shaffer Posted April 20, 2000 Share Posted April 20, 2000 Hi - I hope DG is paying attention to these posts. The Vectorworks Users forum (http://peach.ease.lsoft.com/archives/vectorworks-l.html) has had plenty to say about this topic. Printing is a general area where VW needs much improvement. ------------------ d. s h a f f e r a r c h i t e c t Quote Link to comment
Greg G Posted April 20, 2000 Share Posted April 20, 2000 I agree with Doug on this issue. The printing procedure leaves much to be desired. I do hope that this gets to the top of the list for VW 9 improvments. Quote Link to comment
