Rake a stage?
Adam Britt
The simplest way to make a raked stage is to draw the section in a side view and then extrude it.
If you need to make a more complex rake then convert the extrude into 3D polies and reshape the 3D poly.
Another trick you can use if it's simple rake is to use the Create Roof command.
