Christiaan Posted May 9, 2006 Share Posted May 9, 2006 Once you've completed a fit to roof command to a wall is their any easy way to reset that wall back to what was before you did the command? Quote Link to comment
CipesDesign Posted May 9, 2006 Share Posted May 9, 2006 The best way I've found is to create a "dummy" layer and place into it a simple extruded rectangle, with its bottom at the plate height. Then all you need to do is run the FWTR command again, only this time use the dummy layer as the "fit to". HTH's Quote Link to comment
mike m oz Posted May 9, 2006 Share Posted May 9, 2006 Good tip Peter. It would be nice though if there was an undo fit to roof command so that walls could be returned to their oriinal state when required. Quote Link to comment
