This seems to be a consistent problem that in searching through the knowledge bases and tech forums I haven't found a reasonable solution yet.
First the system:
XP Pro SP2
3GHz/1G Ram
100 G Drive
DJ800 (not PS) with latest Drivers (6.11)
VW 11.5.1
If a file has a layer grayed out, it only partially prints, dropping out random bits and pieces.
If the layer is colored gray (not VW forcing gray) it prints fine.
If the layer is not grayed, it prints fine.
I do not find the printing Rasterized or at On Screen Resolution is an acceptable solution, as this increases the time to plot dramatically.
Furthermore, printing to a PDF or other format and then printing is a telling sign. I can do print outs from various pieces of software at many different shades of gray without a problem.
The problem is with VW and the processing it does to Gray a layer for printout. This seems to be a known, re-occuring theme throughout various versions of VW. Has this been addressed in VW 12?
First the system:
XP Pro SP2
3GHz/1G Ram
100 G Drive
VW 11.5.1
Randy
