Help - a script to sort / reorder symbol names within a database worksheet please
Flair-Studio
Hi,
I am currently completing my custom electrical symbols library (UK based) have prepared all the symbols I need and assigned a custom record.
This time I want to use a workseet as legend, very simple with an image feature and the symbol description, eventually also the count.
How can I reorder the symbols within said workseet so that fused spurs are close to one another, same for switches, etc? Here is a screenshot of what achieved so far (still a lot to do).
Thank you
4 answers to this question
Hello @Flair-Studio,
   If you are using a Worksheet as you say, in your worksheet column header for the SymbolName, do you have the Sort menu set to Ascending or Descending? If it is set to None you will get a random order.
   To get to the Sort control, click on the little button at the right of the column header formula, as shown in the picture below. The dialog shown will appear.
   You can also use the Graphic Legend tool to do something similar with symbol names and images, but I don't know if you can format other information like you can in a Worksheet.
Raymond
