Miss Posted July 9, 2024 Share Posted July 9, 2024 What is the easiest way to create a window like this, please can someone give me the setting I need to create this style of window in a wall. Using 2023 VW Quote Link to comment
zoomer Posted July 9, 2024 Share Posted July 9, 2024 20 minutes ago, Miss said: What is the easiest way to create a window like this I hope you don't wish to show the nice profiled jambs in your screenshot. Jamb profiles in VW will always be simple rectangles. You would need to create your own Window geometry and insert it in the Wall as a Symbol. Beside I see a double swing Window with (?) that black grid thing, don't know the name. Or not sure if it is a framed glazing only. This can be set up in the Window Settings. You can show different colors/appearances by assigning different Classes to Jamb/Sash inner and outer side. Quote Link to comment
Miss Posted July 9, 2024 Author Share Posted July 9, 2024 Im confused. why do I need to turn it into a symbol? is it a way to do what I want to do just from the settings directly Quote Link to comment
Miss Posted July 9, 2024 Author Share Posted July 9, 2024 I just want to add bar but the vertical bar setting isn't doing anything when I try to change that Quote Link to comment
Pat Stanford Posted July 9, 2024 Share Posted July 9, 2024 I believe the settings you are looking for are under Munitins to set the number of vertical horizontal lights. Quote Link to comment
Miss Posted July 9, 2024 Author Share Posted July 9, 2024 Yes! This is the setting I'm looking for but I can't find it anywhere Quote Link to comment
Miss Posted July 9, 2024 Author Share Posted July 9, 2024 This is the closest I can do, usually the setting I need is under muntins vertical/horizontal bar but I'm guessing its under glazing bars now? Quote Link to comment
Miss Posted July 9, 2024 Author Share Posted July 9, 2024 Also why is it so hard to texture door and window frames? Now we have to do it through 'class' instead of texture? Quote Link to comment
Pat Stanford Posted July 9, 2024 Share Posted July 9, 2024 Are you using a localized version of VW? The current VW2024 English release still shows Muntins. Quote Link to comment
Tom W. Posted July 9, 2024 Share Posted July 9, 2024 In UK version it is 'Glazing Bars' not 'Muntins' but it's the same thing. Should be just a case of setting Vertical Bars to 1 + Horizontal Bars to 4. But I am not sure what Configuration you are using @Miss ('General' tab): is it possible you have it set to 'Hung'? What you want is 'Casement'. Quote Link to comment
