Hi! Is there any way to be able to edit the transparency of vw hardscapes in autocad? If I make a normal polygon with hatches it will work. I have previously only drawn 2d plans and now that I have switched to 3d drawing this problem came up when I send my work to other designers. So normally I have looked at the image in autocad and added transparency to the surfaces so that the position drawing shows "through" This no longer works when the plan has a hardscape. Ideas, tips?
Minna
Minna
4 answers to this question
