VW2024 Data Tag constraints not working
Tom W.
4 answers to this question
It does seem to be different between VW2023 and VW2024.
What seemed to work for me was to edit the Style and select the rounded rectgangle and choose the Constrain Left and Right options in the OIP.
That should be a one stop fix for all your instances.
I did check the 2023 file and it also did not have the constraints on the rectangle.
So I don't know what is different.  Hopefully Nikolay will let us know what we are not seeing.
Thank you Pat I appreciate you looking at it + finding a workaround!
It's strange because other tags where the text is constrained to geometry in the same way work fine i.e. a Line:
and a Rectangle:
So perhaps it's something peculiar about Rounded Rectangles...?
We'll see what Nikolay says!
Hello @Tom W.,
Firstly, this should be happening with all graphics, not just rounded rectangles. I suppose that in the other 2 cases mentioned above your text objects have Left alignment selected and not Center, as it is in the rounded rectangle tag.
I think that you have found a bug here caused by the U4 updates to the constraints system. I will log a VB about it and work on its fix.
Sorry for the inconvenience!
Best Regards,
Nikolay Zhelyazkov
You are right!
Thanks for confirming + for filing the bug.
