Peter Telleman Posted March 26 Share Posted March 26 Hi Everyone, I'm making a worksheet for cables. The company I work for doesn't use the cable tool, but works with symbols for different cables. These symbols go into 3 different Layers. My worksheet works fine for each of the individual layers. My idea was to put all three layers in the criteria, so at edit criteria, I add three lines, each saying "Layer is NameOfLayer". As soon as I have more than one Layer mentioned in the criteria it finds no symbols anymore. My logic thought what I did was the way to tell the worksheet in those three Layers, but clearly I was mistaking. What is the correct way to select the Layers my worksheet should look in to for symbols? best regards, Peter @Pat Stanfordmaybe right up your alley?? Quote Link to comment
Tom W. Posted March 26 Share Posted March 26 Sounds like you're using 'All criteria in this set' instead of 'Any criteria in this set'. The former will look for symbols which are on all three layers at the same time which clearly isn't going to happen. The latter will look for symbols which are on either one of the three layers. The former equates to 'Layer 1' and 'Layer 2' and 'Layer 3'. The latter equates to 'Layer 1' or 'Layer 2' or 'Layer 3'. 1 Quote Link to comment
Pat Stanford Posted March 26 Share Posted March 26 I agree with @Tom W. Make sure your layer names are in an ANY block instead of an ALL block. 1 Quote Link to comment
Peter Telleman Posted March 27 Author Share Posted March 27 Thanks Tom, that did the trick! Quote Link to comment
Peter Telleman Posted March 27 Author Share Posted March 27 Hi Tom and Pat, Clearly I'm not the expert on worksheets, is it possible you can have a look at my other worksheet related question? Quote Link to comment
Peter Telleman Posted April 2 Author Share Posted April 2 @Tom W. @Pat Stanford I've come across something I'd like to change in the worksheet, the ANY block works brilliant, but it counts everything in those layers, which includes arrows and comments. I don't want those in my worksheet (a blank row with an amount). Is it possible to leave the any blocks for the layers, but to only count symbols in those layers? Quote Link to comment
Tom W. Posted April 2 Share Posted April 2 15 minutes ago, Peter Telleman said: @Tom W. @Pat Stanford I've come across something I'd like to change in the worksheet, the ANY block works brilliant, but it counts everything in those layers, which includes arrows and comments. I don't want those in my worksheet (a blank row with an amount). Is it possible to leave the any blocks for the layers, but to only count symbols in those layers? Did you watch that Worksheets Coffee Break yet as selecting Criteria is covered in some detail...? It's got to be worth spending a bit of time gaining an understanding of the basics then coming back here once you hit more advanced problems... Quote Link to comment
Pat Stanford Posted April 2 Share Posted April 2 Post a screen shot of your criteria and we might be able to help. Quote Link to comment
Peter Telleman Posted April 3 Author Share Posted April 3 @Tom W. Haven't come far on the video yet, having quite the busy week to be able watch the full hour at once, am 25 minutes in so far. But rest assured, I'm very much into learning as much as I can. I just also see this Forum as a way to learn things. With the added advantage that I usually get answers pretty quickly (I've spend hours looking through manuals and videos not finding answers, that on the forum get quick and clear answers). Do really like this video so far yet, very pleasant and clear explanation, not all coffee breaks I've seen are this enjoyable to watch. @Pat Stanford I've applied the any criteria that works like a dream for the different layers. But I only want to see the symbols, not the scribbles that are also in those layers. I've tried adding the type = symbol criteria, but since it's set to look for any criteria, it then lists all kind of symbols, not just in the layers I want it to look through. That's where I get stuck. Thanks for all the help. Peter 1 Quote Link to comment
Tom W. Posted April 3 Share Posted April 3 I only suggested the video because Michael explains how criteria works very well + you would probably understand it better watching that than having it explained here. Have a look at 34:00 onwards. To incorporate 'Type is symbol' in your criteria you want to do something like this: Now it is looking for objects which are Symbols AND are on Design Layer-1 OR Design Layer-2 OR Design Layer-3. 2 Quote Link to comment
Peter Telleman Posted April 3 Author Share Posted April 3 (edited) @Tom W. What you have there is exactly what I wanted to do, but I have trouble adding the all criteria row you have at the top. How do I add that? And I loved the suggestion, because it's one of the best coffee break I've seen so far. Edited April 3 by Peter Telleman Quote Link to comment
Tom W. Posted April 3 Share Posted April 3 Cool. 15 minutes ago, Peter Telleman said: but I have trouble adding the all criteria row you have at the top. How do I add that? If you click any row in the 'Criteria' column you can select 'All' or 'Any criteria': Click + drag in the '#' column to reorder rows. Quote Link to comment
