Dup-Along=Path, Smart Options
Unless I am very much mistaken, menu commands can't be activated using the Smart Options display. If you want a quick way to access it then you could use the F key and use the quick search bar. That will hold it for every subsequent use of the F key. Otherwise, there is always the Last Command right-click option or the keyboard shortcut.
21 minutes ago, VIRTUALENVIRONS said:
That was the option I wanted.....thanks.
Would be fairly easy to put it into a macro on a stream deck or something similar.  It wouldn't be worth getting a stream deck for one command, but if you are looking for shortcuts for a lot of things like that, it could be worthwhile.  Let me know if you are interested and I can help you out.
