Often single walls don't cut it (no pun intended).
CLT construction for example usually has a different S.O. to the brickwork opening and we have built many models with multiple walls, rather than one single wall with components.
Currently the VW window assumes the S.O. is the same straight through the wall. This is rarely the case.
Therefore creating separate walls, and separate openings, and having the window hosted by the wall that it is fixed to, gets around this problem but it can get complicated.
One window to rule them all, is what we want, what we really, really want.
shorter
4 answers to this question
