Solace Posted December 2, 2023 Share Posted December 2, 2023 Does anyone know why this is happening? I draw a wall and it doesn't come up the set wall height for that layer? Quote Link to comment
0 michaelk Posted December 2, 2023 Share Posted December 2, 2023 Check out the alert at the bottom of the image you posted. "A component of this wall is using a story bound that does not exist". If the wall is styled, edit the components of the style. If it's not styled you can edit the components right from the OIP. Check each component to see what the bounds are. If that makes zero sense, post a file with the wall in it. 🙂 1 Quote Link to comment
0 Solace Posted December 2, 2023 Author Share Posted December 2, 2023 this worked! thank you! Quote Link to comment
0 Solace Posted December 2, 2023 Author Share Posted December 2, 2023 oh I can fix it after I draw it but how come new walls still have the same issue? Quote Link to comment
0 Tom W. Posted December 2, 2023 Share Posted December 2, 2023 9 minutes ago, Solace said: oh I can fix it after I draw it but how come new walls still have the same issue? Like Michael says, edit the Wall Style then the changes will affect all the Walls in the drawing plus all future instances 1 Quote Link to comment
0 Pat Stanford Posted December 2, 2023 Share Posted December 2, 2023 If you are not using Storys in your drawing make sure you select a Fixed Height Wall Style instead of a Story Bound Wall Style. Or figure out what Story Layer is missing and add that to your drawing. Quote Link to comment
0 Solace Posted December 2, 2023 Author Share Posted December 2, 2023 Sounds good. thank you all! Quote Link to comment
Solace
6 answers to this question
