aage.langedrag Posted November 16, 2023 Share Posted November 16, 2023 Which formulas must I use to find Landscape areas and Hardscape where the objects are not marked as "Closed"? I want to create a data visualization that can color all my objects that are not "Closed". Or if that doesn't work, I want to be able to take out a Worksheet that shows me whether objects are closed or not. A big wish I have is if someone can give me a simple visual overview of Vectorwoks' Plug-in Objects (Built-in) and their properties and which formulas I have to use to retrieve these properties in the Data Manager for IFC mapping, Woorksheets , Data Tags, etc.? I keep finding that a few of my Landscape areas and Hardscapes are sometimes not marked as "Closed". This is not always the first thing I look for, so often there are quite a few errors that I have to search for before I discover that the object is not closed. I therefore want to insert a visual check in my model with hundreds of objects so that I can check these before sending out to IFC. https://app-help.vectorworks.net/2023/eng/VW2023_Guide/Shapes1/Closing_and_opening_polygons_and_polylines.htm Quote Link to comment
Tom W. Posted November 16, 2023 Share Posted November 16, 2023 1 hour ago, aage.langedrag said: Which formulas must I use to find Landscape areas and Hardscape where the objects are not marked as "Closed"? There is this vectorscript function: But I have no idea how to use it in a script! Hopefully @Pat Stanford @michaelk or someone can help out... Would be interested to know 2 Quote Link to comment
Pat Stanford Posted November 24, 2023 Share Posted November 24, 2023 Did you get this settled already or do you still need a solution to close your polys / Landmark areas? Quote Link to comment
