hollyyjackson Posted October 21, 2023 Share Posted October 21, 2023 Hi guys. Currently trying to get into CAD and was wondering if anyone knows how I can get a label legend imported into 1 viewport and not the other? Thanks Quote Link to comment
Pat Stanford Posted October 21, 2023 Share Posted October 21, 2023 I don't use Label Legends, so I may be misunderstanding the question, but normally visisibility of objects in Viewports is controlled by Layers and Classes. Try putting your Label Legend in a Class. Then select the viewport you don't want it to show in and click the Classes... button in the OIP (Object Info Palette). Set the visibility of the Label Legend Class to invisible in that viewport. Quote Link to comment
Sam Jones Posted October 21, 2023 Share Posted October 21, 2023 I don't think there is a way to do what you want. Label Legends (LLs) are linked to the Lighting Device instance they report on, and you can only assign one LL to a Lighting Device. You can turn on and off class visibility of LL fields on a viewport by viewport basis. Thiscan make one LL do the job of two by allowing one field to be placed on top of another (or elsewhere), but you won't be able to put the same field in 2 different places in the same LL. You can copy field values to other fields (usually user fields) and you can create your own custom fields. These options will usually achieve the functionality of multiple LLs. Quote Link to comment
Kevin Allen Posted October 21, 2023 Share Posted October 21, 2023 The ;parts; of the label legend can be classed. There is a root class indicated in the Spotlight preferences. You, you can use that and turn it off as desired. I would guess if want to show different information you might configure that with different classes in the legend definition. 3 Quote Link to comment
aheininen Posted October 31, 2023 Share Posted October 31, 2023 On possibility is to use Data-Tags in viewport to show information that you want to show in each. With different Data-Tag between viewports you can see data that is defined in different Data-Tags. I have Data-Tag that is similar visually and in data to my normal Label Legend. With that Data-Tag I can easily visualize ID and Addr even in oddly angled front views. On normal Top/Plan viewport I use just Label Legend because it is usually fastest way to show that data. Data-Tag is IMO easier to move if viewport is crowded, one click to move all fields compared to LL where you have to move all fields separately. Quote Link to comment
