In this situation I have two layers, one with pdf's as reference and one with my design. The problem i'm having is if I rotate the camera in my design layer the pdf layer doesn't follow, it stayes in a kind of screen plane mode.. Same thing if I activate the pdf layer and rotate the camera. Then the pdf's are "on the ground" but the design layer is floating in screen mode.
I've had this problem before and just worked around it, but I'm sure it's a setting or a workflow thing I have done at some point but I don't understand how to fix it. Some help would be appreciated.
MFpsrig
4 answers to this question
