DSmith2300 Posted August 30, 2023 Share Posted August 30, 2023 (edited) Is it possible to roll back to a previous service pack? SP7 is hanging and crashing during data tag edits. EDIT: I googled it and there are mentions of using the Updater. No luck with that. No options for going backwards. Thanks Edited August 31, 2023 by DSmith2300 Quote Link to comment
0 mike m oz Posted August 31, 2023 Share Posted August 31, 2023 Try deleting your User folder and then let Vectorworks create a new one when you restart it. In Vectorworks Preferences under the User Folders tab there is a Reveal in Finder button. 1 Quote Link to comment
0 DSmith2300 Posted August 31, 2023 Author Share Posted August 31, 2023 (edited) Thanks. Won't that delete all my interface preferences etc? I found it and this was the stuff in it. Do I really want to delete all of that!?!? I don't want to 'reset preferences' just roll back to a previous version. Edited August 31, 2023 by DSmith2300 Quote Link to comment
0 rDesign Posted August 31, 2023 Share Posted August 31, 2023 (edited) If you use the Vectorworks Updater application in your Vw 2023 application folder you can choose which version of SP you want to roll back to. 'Change Version' is Hidden for some reason, so you have to hold down the Alt / Option Key when clicking Advanced Options in order to be able to do this. 1) Click on Advanced Options while holding down the Alt / Option Key: 2) At the bottom of the Advanced Options pop-up there is 'Change Versions', click on that and then choose the version you want to roll-back to:: Edited August 31, 2023 by rDesign Added part about holding down Option key, which I forgot. 2 Quote Link to comment
0 rDesign Posted August 31, 2023 Share Posted August 31, 2023 41 minutes ago, DSmith2300 said: EDIT: I googled it and there are mentions of using the Updater. No luck with that. No options for going backwards. The Updater will allow you to roll-back, see my post above this one for instructions. 1 Quote Link to comment
0 DSmith2300 Posted August 31, 2023 Author Share Posted August 31, 2023 (edited) Quote The Updater will allow you to roll-back, see my post above this one for instructions. Awesome thanks!!! I'll come back on here to let you know how that worked. EDIT: YOU DA MAN! The updater is doing its thing now; back to SP6. MANY THANKS!!! Edited August 31, 2023 by DSmith2300 1 Quote Link to comment
DSmith2300
No luck with that.
Thanks
Edited by DSmith2300Link to comment
5 answers to this question
