Niels Timmer Posted March 21, 2023 Share Posted March 21, 2023 Hi all, The Get 3D Info node seems to have a bug. I made a very simple Marionette Network with only one 3D object (extrude) and it gives the following error: Is this a bug or did I do something wrong? Get 3D Info error v2023.vwx Quote Link to comment
Marionette Maven Marissa Farrell Posted March 21, 2023 Marionette Maven Share Posted March 21, 2023 @Niels Timmer If you double click on that node and hit OK and then run again, does the error persist? Which build are you running? Quote Link to comment
Niels Timmer Posted March 21, 2023 Author Share Posted March 21, 2023 Thanks @Marissa Farrell, that helps! I updated to VW 2023 SP4 this morning. Quote Link to comment
Anders Blomberg Posted March 21, 2023 Share Posted March 21, 2023 I'm seeing the exact same issue and solution. Quote Link to comment
Anders Blomberg Posted March 21, 2023 Share Posted March 21, 2023 Actually, it's worse, as I investigated further. If I connect my Obj node to Get 3D Info it returns the error below. It's an infinite loop so when I click Close or Select Node it comes straight back up until I force quit the software. If I first double click and OK the Get 3D Info node and then debug the network everything freezes and I have to force quit VW again. Quote Link to comment
Marionette Maven Marissa Farrell Posted March 21, 2023 Marionette Maven Share Posted March 21, 2023 Which build are you using? Quote Link to comment
Anders Blomberg Posted March 22, 2023 Share Posted March 22, 2023 I tend to stick to the latest, in this case 2023 SP4 (Build 693289). Quote Link to comment
Moe_90 Posted March 13 Share Posted March 13 Hello everyone, is there any update regards the Get 3D info node? i also get errors using it Quote Link to comment
HebHeb Posted April 4 Share Posted April 4 (edited) same bug for me (since a few months?) I just deleted everything I didn't needed inside the node (for example: I just needed volume) then it worked fine 🙂 Edited April 4 by HebHeb Quote Link to comment
