Niels Timmer
24 -
Calendar
Everything posted by Niels Timmer
There seem to be two ways to attach IFC data to wall styles but one doesn't seem to work. In the attached screenshots the two ways are shown. I know that Replace IFC data should be checked, so that is not the problem here. Do others experience this as well?
Hello, Usually I make elevations by creating section viewports en using renderworks as my background render mode. Since VW2022 windows look very strange in these viewports. Here is a comparison between VW2021 and VW2022: These are the render modes from top to bottom: Hidden line OpenGL / Shaded Renderworks (Realistic Exterior Fast) All classes are set to visible, yet in VW2022 some parts of the window are not rendered. I think this is a bug, or did something change in VW2022 and do I have to do something different to render correct elevations? Any help would be great! window tool renderworks v2021.vwx window tool renderworks v2022.vwx
- 1 reply
- window tool
- renderworks
(and 1 more)
Tagged with:
Window and Door Tool maturity
Niels Timmer replied to Christiaan's question in Wishlist - Feature and Content Requests
What would also be great is if we can control the 3D-appearance of windows/doors with materials instead of classes. Materials have to be fully integrated in Vectorworks or they are quite useless in my opinion. -
The links to the files don't seem to work. Could you please share them again? Would be very helpful!
In the 'Define Material' dialog box are four tabs for entering data. In the Construction tab I can select a classification standard. I can choose between OmniClass and Uniclass. Can I add a custom classification standard to the list? The Vectorworks help says But I can't find any instructions, my Libraries/Defaults/Classification folder is empty. Does anybody knows how this works?
- 1 reply
- materials
- classification
(and 1 more)
Tagged with:
Hello Dom, In a project I'm working on, this node could be very useful. For now it only seems to be working with generic solids, is that correct? And is there a node available that can convert geometry to a generic solid? As you can see in the attached example it creates holes in the object when the control geometry consists of solids (not generic solids but extrudes, etc.). 201012 Reshape node question.vwx
Vectorworks Cloud Publishing starts before upload is finished
Niels Timmer posted a question in Troubleshooting
Hi, As a Vectorworks Service Select member I use cloud publishing a lot. Lately I started noticing that the changes that I made only appeared in my PDF-drawings after publishing two or three times. When you select Store and process on Vectorworks Cloud in the publishing dialog, it always asks to save the file first before publishing. That makes sense, because I want my latest changes to appear in my PDF's. But I think the problem is that the publishing starts before the upload is finished. Does anyone else have this problem? -
How to determine if a line intersects a 3D object
Niels Timmer replied to Niels Timmer's topic in Python Scripting
I managed to make a working Marionette example. The network checks if a three dimensional line intersects a NURBS surface. Marionette Network can be found here: -
Version 1.0.0
23 downloads
Description This node calculates where a line (not a line segment!) and a plane intersect. Input / output The plane is defined by its normal vector and a point on the plane. The line is defined by two points. The output point is where the line and plane intersect. Example Usage The example in the file combines the node with the Get Distance node to check if a three dimensional line intersects with a NURBS surface. This network can be used to create several simulations that can answer questions like: Do sunrays reach a balcony? Is the church tower visible from a window? Etc. Script is based on: https://rosettacode.org/wiki/Find_the_intersection_of_a_line_with_a_plane#Python The node uses numpy. Thanks to DomC for creating a numpy importer node. Niels Timmer March 2020 -
Hi all, In my model I have a straight three dimensional line (3D polygon) and a solid object (extrude or generic solid, for example). Does anyone know how I can determine if the line intersects/crosses the 3D object? I hope someone can help. Best regards,
Vectorworks Bugs when working with Marionette
Niels Timmer replied to Niels Timmer's topic in Marionette
@Marissa Farrell The problem disappears when I restart my computer/VectorWorks. I don't have a file (yet) where I can reproduce the problem. Or are you interested in any file where this problem occurred? @Stephan Moenninghoff Yes, using the menu instead of the keyboard shortcut will not break undo. -
Hi all, When I'm working with the Marionette-tool, very often I get these problems: The OIP does not update when I select different objects. I can only change properties this way: right-click > properties Cmd + z doesn't take me one step back, but a lot of steps. Meaning that cmd + z very often erases my work for the last hour. Redo doesn't work. Edit > Undo doesn't have this problem. Are others also facing these issues? I use Vectorworks on both MacOS and Windows, the described problems occur on both operating systems.
Spaces with auto-boundaries change when they shouldn't
For an apartment building I work with spaces to determine the area of each apartment. My client would like to have the netto area of each apartment, without the area occupied by the shaft. I drew the outer walls of the apartments, and a wall around each shaft. Then with Inner Boundary mode selected, I create the spaces. Works fine. But after a while the reference point of the space moves to inside the shaft and the area of the apartments is displayed incorrectly, because it now shows the area of the shaft. On the attached image it shows the issue: apartment no. 50 has changed its size to the size of the shaft. Does anyone know how to resolve this? (I hope the description of my issue is clear, English is not my native language, feel free to ask questions) -
Thanks for the replies! Unfortunately, I'm not there yet... As you can see in the attachment, I have a list with points that I use to create a polygon. I know which vertices need to be arc vertices, but the Change Vertex Type node doesn't work apparently. Could someone have a quick look at it? (next to the Marionette object is the shape that I would like to have in the end) 190712 ChangeVertexType.vwx
I'm currently facing the same problem: the compose node doesn't work inside a Marionette Object. How would this workaround look like if one of the lines is an arc? (I have two arcs and three straight lines that form a closed shape together)
Nice, it still works in 2019. Saved me a lot of time!
Extrude along multiple paths and use Control Geometry
Yes, now it makes sense to me. Thanks for your replies! I finished the Marionette network and have my first working Marionette object in a building model. -
Thank you, it works! I was almost there... Now I'm curious: what is the difference between the Contents node and the Ungroup node? The output formats (hObjs) look the same. -
In the attached file I have three Marionette Networks. The first network is simple: it extrudes a polygon along a path. The script knows which polygons to use, because I named them 'Profile' and 'Path'. The second network is almost the same, except that instead of one path I created multiple paths and grouped them. The third network is almost the same as the second network, but the third network is wrapped. What I would like is to use the group of paths as 'Control Geometry'. But when I select the wrapped network and the group of paths, right-click and then 'Convert to Object Node...', both the wrapped network and the group of paths seem to disappear. How can I fix this? ExtrudePath.vwx
Thank you for your reply. The second option is what I would like to achieve because we would like to be able to quickly test different shapes and sizes of the curved balconies in a detailed 3D view. I attached two files to clarify what I mean. In the PDF (and also in the .vwx file) you see two polygons and one balcony that has the shape of the first polygon. The 3D balcony was created with the AEC > Create Objects from Shapes... function. I used this function to model the slab, walls and railing/fence object. I hope Marionette can automate the process from polygon to detailed 3D balcony. With the Create Slab node I can create a slab in the shape of the polygon. But if I want my Marionette network to draw a wall object with the Wall node or Round Wall node I can't use a polygon (or an arc or a line) as a parameter. Basically it comes down to this: from polygon to wall. If you could help me with that then I'm almost there (at least I hope so 😉). Curved balconies.vwx Curved balconies.pdf
In Vectorworks I use the "Create objects from shapes" function a lot. I would like to know if there is a Marionette equivalent of this function or if it is easy to script one. My goal is to create a Marionette network that creates curved balconies from a polyline. The balcony has a slab element, wall element as balustrades and a railing/fence element. All these elements follow the same polyline curve.
