Moe_90
23 -
Reputation
4 NeutralPersonal Information
Occupation
Landscape Architect
Hobbies
Fitness
Location
Germany
Problem when create marionette object from a wrap node
Moe_90 replied to Moe_90's topic in Marionette
Update: looking more into the Path Extrude node, and searching the Caves of the internet, i reached that topic from @AlanW from 2016 i ended up using his solution with editing the path extrude node, by removing the lines that responsible for the profile center, and it worked fine with me as i wanted. thanks very much @AlanW -
Hello Everyone, is there anyupdate regarding that topic? unfortunately the edited file and the video are not availabe anymore, is it possible to repost them? that would be so great @Marissa Farrell @AlanW
Hallo Fabrice, is there any update?
Update: i did mange to create the marionette Object, the issue seemed to be with the way the Path is created, for some reason, using compose node to make the path make a problem when creating a marionette Object, so instead, i made the path using 3D points and 3D Poly, which works fine. the issue now, is the center point, on which the profile is using to get extruded along the path, it seems that the Path extude node uses the center of the profile to extrude it along the path. my question now is, can i choose another point on the profile, so the path extrude node uses it to extrude the profile along the path?? -
i tried to recreat the same network, but without the Move and the Rotate Nodes, and it still presist my theory is, somethin goes wrong in the path Extrude node, when the wrapped networks turns into Marionette Object, which i am not sure what is exactly -
Greetings everyone, i am new in marionette, and that is my first week, and while i was trying to create a tool that will create a parametric L-Shape Wall for corners, something doesn't work when i try to make the wrapper into marionette object. i attached the file so you can under stand what i mean. Vectorworks 2023 what could be the reason for such result? Wall.vwx
Hello everyone, is there any update regards the Get 3D info node? i also get errors using it
Issue: Importing IFC Datamapping from VW 2023 to VW 2021
Moe_90 posted a question in Troubleshooting
Hello everyone, i hope you are doing well. i run into an issue while trying to import IFC Datamapping set into an older version of Vectorworks (2021) i used Vectorworks 2023 Datamanager to create class based IFC Mapping, and i saved it, but when i try to import it in Vectorworks 2021 Datamanager, it told me it is an invalid file. is there anyway i can import the Datamapping set for Vectoworks 2023 into Vectorworks 2021? -
Retaing wall tool - Parametric
Moe_90 replied to Moe_90's question in Wishlist - Feature and Content Requests
Thanks for your reply, what i miss in that tool is the ability to create Reataing wall with Profile, like L Profile, or trapazoid Profile for example. is there a way to achieve that result ?? -
it would be helpful to have a tool that creats reating wall for landscape site.
Thanks a lot for your reply, those Demo are really helpful. are you aware of any other sources, where i can find examples for that type of projects, which is being built/was built?
Greeting everyone, I am not sure if that is the right place to post my topic in, but i couldn't find a suitable place, so i am trying here. It is about Landscape projects that use the BIM-Method in Planning and Execution. If there are any well known examples from the world, where I can look and study it? espically in the area of Parks and Pedestrian Zones. that would be very heplful, Thank you guys
Thanks very much, that looks very promissing to explore and try out.
How can i map Object's Geomertric Info im IFC for export
Moe_90 replied to Moe_90's topic in Architecture
so i did some research, and i found this formulas list, which is very helpful in my opinion. https://developer.vectorworks.net/index.php?title=Worksheet_Functions#Text and using expert formulas in the Data Manager, i can map the field i want to the info i want to show my problem now, is how can i add Units symbol to the data field? because the when i use the equation for length, it just map the value, and doesn't show the unit (m², m, kg, etc..) how i can add the Unit symbol to the formulas, any help? -
Update: i have got in contact with service select team in Vectorworks, and the told me that up until now, that feature isn't supported, yet, and maybe in the future it will be there.
