unable to adjust wall thicknesses in object information palette
Ornette
8 answers to this question
You probably have a styled wall.
You have two choices.
  1.  Edit the wall style.  In the OIP 3rd from the top is the pull down for style.  I'm guessing it does not say "Unstyled".
    1. click that pull down and choose edit style to change every wall in the drawing using that style  OR
    2. click the pull down and choose replace to choose a different wall style. OR
  2. Unstyle the wall.  Click the pulldown and choose "Convert to Unstyled Wall"
    1. Now you can click on Components… in the OIP to edit the selected walls components OR
    2. Delete all the components to get a "default" unstyled wall whose thickness can be controlled directly in the OIP.
